- Dec 30, 2020
A metadata vdev speeds up both reads and write. It holds part of the pool data, so it is CRITICAL for the pool and needs redundancy. 3-way mirror is what matches raidz2 for bulk data. With HDDs in raidz#, a metadata vdev cannot be removed.Yes, need that only. Having 128GB. Seems like first I'll need to test and then check. Just a quick question. If i setup drive for metadata, how would i know the difference? Any particular method to test?
A persistent metadata L2ARC speeds up reads only; writes go the HDD pool anyway. Since the L2ARC only holds a copy of the metadata, it is NOT critical and be removed at any time, even when using raidz#; no redundancy required, if the L2ARC devices dies, you lose performance but not data.
For directory browsing only, a metadata L2ARC is the way, and you have the RAM to support it. Go and get one of these Optane 905p after all…
(A regular SSD would do it, but Optane is better.)
Not sure why you'd want both SFP+ and 10GBase-T onboard for a NAS. TrueNAS really only want one interface to your network.Any mATX board in SuperMicro with the LGA3647 or LGA4189 socket? 2xOnboard SAS port would be nice along with 1xBase-T (10GbE) and probably an SFP+ (10GbE). With the case i have, its difficult to find such board. If you can help or put some insight, it would be really helpful. Thank you again
If you absolutely insist, embedded Ice Lake-D boards such as X12SDV-8C-SPT8F have both SFP28 (backwards compatible with SFP+) and 10GBase-T onboard (plus an i350-AM4 which leaves me totally clueless, but I don't work in TelCo…). But the higher clocks of a Xeon Scalable would likely serve you best for maximal performance with SMB.
Onboard SAS is out of fashion in favour of NVMe storage, so you'll need a card for that. What use do you have for the PCIe slots anyway?
