DHCP on 9.10 Jail unselectable
jerryjharrison
First of all, this is has been a freeNas server for years without issue. It has been running 9.10 with a jail getting a DHCP address since 9.10 was released. Recently the server has a valid network stack, but I was not able to access anything from the jail, and the DHCP button on the advanced Jail configuration could not be selected. I became frustrated, wiped out the server completely, and did a fresh install of 9.10 on the server. I even wiped out the zfs pool when re-installing so that I was certain all was completely clean. Tried to create a jail, and got the same issue. The server has no problems on the main interface, but the jails do not even appear to have an interface created.
I tried installing the Owncloud plugin to see what happens with that jail, and it has a NIC, and gets DHCP wiht no problems.
The ifconfig output for the PLUGIN:
root@owncloud_1:/ # ifconfig
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:b0:00:05:0b
        inet 10.0.1.65 netmask 0xffffff00 broadcast 10.0.1.255
        status: active
root@owncloud_1:/ #
The ifconfig output for the JAIL:
root@octest2:/ # ifconfig
lo0: flags=8008<LOOPBACK,MULTICAST> metric 0 mtu 16384
root@octest2:/ #
General Configuration for Jails is just the properly defined jailroot and DHCP is checked.
joeschmuck
Old Man
Check the MAC address of the jail interface, it could be duplicated with another jail/plugin and we have seen this on the forum for a while now, hopefully this is your problem too. Run Static IPs if you want to ensure stuff like this doesn't happen again.
jerryjharrison
Thanks Joe. I had searched the Forum, but must have missed discussions about this issue. Static IP configuration, and creating a new jail seemed to get it back on the network. reconfiguring all of my jails now...
philhu
the jail dhcp problem is listed as fixed in the 9.10.1 release notes
