I'm running 9.1.1 64 bit on a 2010 Intel DB43LD mATX board
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-db43ld.html
4gb RAM, single 2T SATA drive (temporary)
The issue is this. If I set the network config to use DHCP, DNS works fine. I can ping, resolve names, etc. I have 3 DNS servers manually entered (I've tried Google, OpenDNS, severs on our network at work) and changing these has no effect. Changing the network to use a static IP (same IP as DHCP or another on the same block) immediately causes DNS to stop working. I cannot see plugins available, can't resolve names, ping by name, etc. Change it back to DHCP and everything is golden.
I appreciate any assistance you can provide with this. I think I've provided the information as required in the rules.
IFCONFIG results with DHCP set:
ifconfig em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO> ether 70:71:bc:0d:ac:95 inet6 fe80::7271:bcff:fe0d:ac95%em0 prefixlen 64 scopeid 0x1 inet 128.226.31.207 netmask 0xfffffe00 broadcast 128.226.31.255 nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> media: Ethernet autoselect (100baseTX <full-duplex>) status: active ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536 nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0xb inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
IFCONFIG results with static IP set:
