Monkey_Demon
- Nov 11, 2016
I'm new to FreeNAS but had been using Plex for about 5 years until about 2 years ago, when my old NAS stopped supporting the latest version of Plex. I've also used *nix computers since the late 1970s, but only returned to BSD when I started using FreeNAS.
I started following "Installing Plex Media Server in a FreeNAS Jail (FreeBSD port)" by jostro. This tutorial covers the nitty-gritty of using the CLI to manually set up the PMS in a jail. Given that it says installing the native package is optional, I skipped directly to the instructions for a port install. After establishing a SSH connection to the server and logging in a root, I issued these commands:
This results in the following (error) messages:
It appears portsnap no longer supports the version of FreeBSD bundled with FreeNAS 11.1. So now what do I do?
jls # To discover the jail number (<jn>) of plexpasspms
jexec <jn> # Start a shell in that jail
portsnap fetch # Download a current snapshot of the ports collection
portsnap extract # Extract it and store the snapshot in /usr/ports -- There are quite a few!!!
cd /usr/ports/multimedia/plexmediaserver-plexpass # Go to the directory of the plexpass PMS port
make install
===> Building/installing dialog4ports as it is required for the config dialog
===> Cleaning for dialog4ports-0.1.6
/!\ ERROR: /!\
Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release.
No support will be provided if you silence this message by defining
ALLOW_UNSUPPORTED_SYSTEM.
*** Error code 1
Stop.
make[3]: stopped in /usr/ports/ports-mgmt/dialog4ports
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/ports-mgmt/dialog4ports
===> Options unchanged
/!\ ERROR: /!\
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/multimedia/plexmediaserver-plexpass
*** Error code 1
Stop.
make: stopped in /usr/ports/multimedia/plexmediaserver-plexpass
root@plexpasspms:/usr/ports/multimedia/plexmediaserver-plexpass # portsnap fetch update
Looking up portsnap.FreeBSD.org mirrors... 6 mirrors found.
Fetching snapshot tag from your-org.portsnap.freebsd.org... done.
Fetching snapshot metadata... done.
Updating from Mon Aug 6 16:59:34 EDT 2018 to Mon Aug 6 17:17:14 EDT 2018.
Fetching 5 metadata patches... done.
Applying metadata patches... done.
Fetching 0 metadata files... done.
Fetching 1 patches.
(1/1) 100.00% done.
done.
Applying patches...
done.
Fetching 0 new ports or files... done.
Removing old files and directories... done.
Extracting new files:
/usr/ports/devel/py-black/
Building new INDEX files... done.
root@plexpasspms:/usr/ports/multimedia/plexmediaserver-plexpass # make install
/!\ ERROR: /!\
*** Error code 1
Stop.
*** Error code 1
Stop.
/!\ ERROR: /!\
*** Error code 1
Stop.
*** Error code 1
Stop.
