Help needed: Unifi8 on CORE
mrMuppet
i would like to have Unifi8 running on my CORE TrueNAS-13.0-U6. But pkg doesn't has it at the moment and building it stopps with the following error:
*** Configure:  Fatal Error:  /usr/sbin/dtrace doesn't support -h flag
*** Your installed dtrace doesn't support the -h switch to compile a D
*** program into a C header. Can't continue.
===>  Script "Configure" failed unexpectedly.
Please report the problem to mat@FreeBSD.org [maintainer] and attach the
"/usr/ports/lang/perl5.36/work/perl-5.36.2/config.log" including the output
of the failure of your make command. Also, it might be a good idea to provide
an overview of all packages installed on your system (e.g. a
/usr/local/sbin/pkg-static info -g -Ea).
*** Error code 1
Stop.
make[9]: stopped in /usr/ports/lang/perl5.36
*** Error code 1
Stop.
make[8]: stopped in /usr/ports/devel/p5-Locale-gettext
*** Error code 1
Stop.
make[7]: stopped in /usr/ports/misc/help2man
*** Error code 1
Stop.
make[6]: stopped in /usr/ports/print/texinfo
*** Error code 1
Stop.
make[5]: stopped in /usr/ports/devel/m4
*** Error code 1
Stop.
make[4]: stopped in /usr/ports/devel/bison
*** Error code 1
Stop.
make[3]: stopped in /usr/ports/shells/bash
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/devel/sbt
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/archivers/snappy-java
*** Error code 1
Stop.
make: stopped in /usr/ports/net-mgmt/unifi8
Dopamin3
Quarterly doesn't have it, but latest does (choose 13.2-RELEASE for your iocage jail.) Change your pkg repo from quarterly to latest in your jail, I usually do this for most of my jails anyway to get software updates quicker.
