Bruce Wilfong
- Mar 25, 2016
Trying to update plex from 1.10.1.4602 to 1.11.0.4633, after I used the command portupgrade -ai I received this message:
---> Session started at: Mon, 25 Dec 2017 20:49:39 -0800
[Reading data from pkg(8) ... - 69 packages found - done]
---> Upgrade of multimedia/plexmediaserver-plexpass started at: Mon, 25 Dec 2017 20:49:41 -0800
---> Upgrading 'plexmediaserver-plexpass-1.10.1.4602' to 'plexmediaserver-plexpass-1.11.0.4633' (multimedia/plexmediaserver-plexpass)
OK? [yes] yes
---> Build of multimedia/plexmediaserver-plexpass started at: Mon, 25 Dec 2017 20:49:49 -0800
---> Building '/usr/ports/multimedia/plexmediaserver-plexpass'
===> Cleaning for plexmediaserver-plexpass-1.11.0.4633
/!\ ERROR: /!\
Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release.
No support will be provided if you silence this message by defining
ALLOW_UNSUPPORTED_SYSTEM.
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/multimedia/plexmediaserver-plexpass
*** Error code 1
I have updated to the latest FREENAS Version (Current Train: FreeNAS-11-STABLE (...) no update are available. Not sure how to fix this.
I did see a message in the forums about changing my make.cnf by adding in ALLOW_UNSUPPORTED_SYSTEM=YES but I can not find the file to change.
Thanks for any help.
OK? [yes] yes
/!\ ERROR: /!\
*** Error code 1
Stop.
*** Error code 1
