Hello everyone,
Planning out a new FreeNAS build that I'm quite excited about. Here's the lineup I've got planned so far:
Chassis: Supermicro SYS-5019S-WR (Includes the Motherboard and PSUs)
Motherboard: Supermicro X11SSW-F
CPU: Xeon E3-1240V6
RAM: 16gb Micron MTA18ASF2G72AZ-2G3A1
Boot Disk: 2x 64gb SuperMicro SATA DOMs
Storage Drives: 4x HGST Ultrastar 7K4000 (These are being repurposed from a different system. Otherwise, I'd be going with Seagate Iron Wolfs)
What I'm considering now is adding a SLOG device to improve performance. My connection options are 4x standard SATA connectors, and 1x M.2 slot. The drawback to the SATA connectors is that there's no actual spots in the case to mount additional drives. I'd have to rig something up for them to be fastened into the space that would normally be taken up by PCIe cards.
I haven't yet confirmed what the best candidate for an M.2 SSD would be, but I'm thinking something like a 250gb Samsung 970 EVO NVMe
The first consideration I'm struggling with is the importance doing a mirrored VDEV for the SLOG. Given that this will be enduring quite a bit of writes, I'm a bit concerned about the durability of SSDs in the long-run. If that concern is legitimate, what I could do is get 2x Micron 5200's (Which have pretty insane durability for SSDs)
After thinking on this, I realized another option which would be to use the two SATA DOMs as the (mirrored) SLOG, and the M.2 as the boot disk. I'm thinking that's probably less appealing overall, but worth considering anyways.
I'm going to keep researching this, but wanted to put this one to the forum and see if anyone had strong advice one way or another on this. Thanks in advance for any input!
CPU: Xeon E3-1240V6
