Jasonachmed
- Feb 24, 2021
I know this is a common question but how do I know if my drive need replaced?
I have 10x3tb drives in raidz 2 and i am getting the below alert. When I run a SMART test it comes back with SUCCESS.
Do I need to replace this drive or do I need to run something to repair bad sectors?
CRITICAL Device: /dev/ada5, 6 Currently unreadable (pending) sectors. 2021-03-15 14:14:53
@truenas[~]# zpool status pool: Main state: ONLINE scan: scrub repaired 0B in 07:24:18 with 0 errors on Sun Mar 7 07:24:19 2021 config: NAME STATE READ WRITE CKSUM Main ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/b512616f-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b5e351d1-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b6a85d1a-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b777622e-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b8512d2e-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b91a62e1-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/b9e20c9e-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/bab16311-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/bb7a63ba-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 gptid/bc48e59f-c796-11e5-922c-305a3a48b6cd ONLINE 0 0 0 errors: No known data errors pool: boot-pool state: ONLINE scan: scrub repaired 0B in 00:01:03 with 0 errors on Wed Mar 10 03:46:03 2021 config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
@truenas[~]# smartctl -a /dev/ada5 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WCC4N4AETD4V LU WWN Device Id: 5 0014ee 20c916c30 Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Mar 15 17:40:13 2021 SAST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (38880) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 390) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 43 3 Spin_Up_Time 0x0027 188 180 021 Pre-fail Always - 5575 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 420 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44439 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 418 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 333 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 497 194 Temperature_Celsius 0x0022 116 109 000 Old_age Always - 34 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 6 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 6 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 44184 - # 2 Short offline Completed without error 00% 43995 - # 3 Extended offline Aborted by host 90% 43995 - # 4 Short offline Completed without error 00% 43995 - # 5 Short offline Completed without error 00% 43990 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
