Hello!
I'm fairly new to this but I'll give it a try.
I've got 4x3tb drives running in raidz1.
So, after my latest extended offline smart test I've got some errors. (8 Offline uncorrectable sectors)
Does this mean it's time to replace the disk? I've got one already on the way if this is the case.
smartctl -a /dev/ada3 gives me this.
=== START OF INFORMATION SECTION === Model Family: Seagate Barracuda 3.5 Device Model: ST3000DM008-2DM166 Serial Number: Z503Z849 LU WWN Device Id: 5 000c50 092fa9be9 Firmware Version: CC26 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Thu Apr 1 08:38:06 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 116) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 89) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 316) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1085) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 113 099 006 Pre-fail Always - 54316128 3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 087 087 020 Old_age Always - 13717 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 17131359 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 23193 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 360 183 Runtime_Bad_Block 0x0032 089 089 000 Old_age Always - 11 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 096 000 Old_age Always - 1 1 32 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 068 052 045 Old_age Always - 32 (Min/Max 30/36) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 134 193 Load_Cycle_Count 0x0032 083 083 000 Old_age Always - 34306 194 Temperature_Celsius 0x0022 032 048 000 Old_age Always - 32 (0 19 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 8 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 8 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 34 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3724h+57m+45.257s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 19054618730 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 177423389315 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 40% 23188 4123129888 # 2 Short offline Completed without error 00% 23138 - # 3 Short offline Completed without error 00% 23091 - # 4 Short offline Completed without error 00% 23043 - # 5 Short offline Completed without error 00% 22995 - # 6 Short offline Completed without error 00% 22947 - # 7 Short offline Completed without error 00% 22899 - # 8 Extended offline Completed without error 00% 22889 - # 9 Short offline Completed without error 00% 22884 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If selective selt-test is pending on power-up, resume after 0 minute delay.
