Smartctl wrong/right? Second hand drive shows zero hours
Keyakinan
Hi!
I've just bought a second hand HDD (Seagate IronWolf Pro 14tb), should only be used for a month tops.
Right now I've done a conveyance scan, short and extended trough the GUI of TrueNAS, see results below.
I am running a long scan for about 6-7 hours now and the drive does not have any indication ( as far as I can see) that it is second hand.
Am I lucky? They guy acted wierd about it when I asked him if he resetted the SMART values.
So chances this is an HDD straight from factory (they come with blank SMART results if I'm right or something else going on?
Also if the test come back good, is it still wise to run badblocks after this?
Might be formated funky but Power_On_Hours says "6"
smartctl -a /dev/ada1
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate IronWolf Pro
Device Model: ST14000NE0008-2JK101
Serial Number: ZHZ2HSSZ
LU WWN Device Id: 5 000c50 0b5530972
Firmware Version: EN01
User Capacity: 14,000,519,643,136 bytes [14.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Jan 26 22:30:56 2021 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 247) Self-test routine in progress...
70% of test remaining.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1263) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 083 083 044 Pre-fail Always - 213316086
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 4
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 064 060 045 Pre-fail Always - 2408382
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 6
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 4
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 065 040 Old_age Always - 34 (Min/Max 23/35)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 3
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 10
194 Temperature_Celsius 0x0022 034 040 000 Old_age Always - 34 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 083 083 000 Old_age Always - 213316086
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 6 (148 198 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 0
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 213316086
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Self-test routine in progress 70% 6 -
# 2 Short offline Completed without error 00% 1 -
# 3 Conveyance offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I have seen mention of a process that could be used on some (older, as it's apparently now secured on more recent models) Seagate drives that a connection with RS.232 to the drive can be used to reset the values.
Very hard to say how you would know if that had been done or not though.
Etorix
Badblocks after full SMART tests is the recommended burn-in process.
The seller reacting weirdly might be an indication that he somehow wiped the SMART data and did not expect to be caught. But you can't complain about getting a second-hand drive when you bought just that. If the tests show no error, all should be fine.
Keyakinan
Thanks for your reaction, I will run badblocks!
I'm not complaining about a second-hand drive. But he says its a month old and if it is 3 years old with 26k hours then I'm complaining ;)
Alecmascot
Run the serial number through Seagate's warranty system.
pschatz100
According to suggested drive burn-in comments, after you run badblocks, you should run the SMART Long test again. That will give you a more complete picture of the drive.
