websmith
- Sep 20, 2018
Today I got two emails from one of my truenas servers.
First one stated:
Then 1 minute after I received:
I have looked throught the log files on the server and also done a zpool status:
So everything seems to be in order - at least it looks "normal" - I am aware that running with just one drive for ZIL is probably not good, but its good enough for me
So anything else I can look in to find out why truenas suddenly decided that either my pool was offline, or sent wrong mails?
I am a bit scared now, since I tend to take mails like this very serious, but since everything seems to be okay I don't know what to do.
Thanks in advance
First one stated:
New alerts: * Pool tank2 state is OFFLINE: None Current alerts: * Pool tank2 state is OFFLINE: None
The following alert has been cleared: * Pool tank2 state is OFFLINE: None
pool: tank2 state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(5) for details. scan: scrub repaired 0B in 03:14:35 with 0 errors on Sun Dec 5 03:14:40 2021 config: NAME STATE READ WRITE CKSUM tank2 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/0d932ec4-62c9-11e9-8f21-a0369f09f4ea ONLINE 0 0 0 gptid/0e519d79-62c9-11e9-8f21-a0369f09f4ea ONLINE 0 0 0 logs gpt/tank2_log ONLINE 0 0 0 errors: No known data errors
root@nas:/var/log # smartctl -a /dev/ada2 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Serial Number: WD-WX11DA8DHFV5 LU WWN Device Id: 5 0014ee 2bb432b67 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Dec 11 00:25:02 2021 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 2804) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 682) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 234 197 021 Pre-fail Always - 7266 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 188 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 22997 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 147 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 108 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5772 194 Temperature_Celsius 0x0022 114 106 000 Old_age Always - 38 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 22777 - # 2 Extended offline Completed without error 00% 22058 - # 3 Extended offline Completed without error 00% 21313 - # 4 Extended offline Completed without error 00% 20594 - # 5 Extended offline Completed without error 00% 19851 - # 6 Extended offline Completed without error 00% 19108 - # 7 Extended offline Completed without error 00% 18389 - # 8 Extended offline Completed without error 00% 17645 - # 9 Extended offline Completed without error 00% 16926 - #10 Extended offline Completed without error 00% 16184 - #11 Extended offline Completed without error 00% 15514 - #12 Extended offline Completed without error 00% 14771 - #13 Extended offline Completed without error 00% 14027 - #14 Extended offline Completed without error 00% 13310 - #15 Extended offline Completed without error 00% 12568 - #16 Extended offline Completed without error 00% 11848 - #17 Extended offline Completed without error 00% 11105 - #18 Extended offline Completed without error 00% 9643 - #19 Extended offline Completed without error 00% 8900 - #20 Extended offline Completed without error 00% 8181 - #21 Extended offline Completed without error 00% 7439 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
root@nas:/var/log # smartctl -a /dev/ada4 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Serial Number: WD-WX11DA8DHSD2 LU WWN Device Id: 5 0014ee 265ed8ac1 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Dec 11 00:26:09 2021 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 4604) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 700) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 234 197 021 Pre-fail Always - 7300 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 188 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 22980 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 147 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 111 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5793 194 Temperature_Celsius 0x0022 111 103 000 Old_age Always - 41 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 22760 - # 2 Extended offline Completed without error 00% 22041 - # 3 Extended offline Completed without error 00% 21297 - # 4 Extended offline Completed without error 00% 20578 - # 5 Extended offline Completed without error 00% 19834 - # 6 Extended offline Completed without error 00% 19091 - # 7 Extended offline Completed without error 00% 18372 - # 8 Extended offline Completed without error 00% 17629 - # 9 Extended offline Completed without error 00% 16909 - #10 Extended offline Completed without error 00% 16168 - #11 Extended offline Completed without error 00% 15497 - #12 Extended offline Completed without error 00% 14754 - #13 Extended offline Completed without error 00% 14011 - #14 Extended offline Completed without error 00% 13293 - #15 Extended offline Completed without error 00% 12551 - #16 Extended offline Completed without error 00% 11832 - #17 Extended offline Completed without error 00% 11089 - #18 Extended offline Completed without error 00% 9627 - #19 Extended offline Completed without error 00% 8884 - #20 Extended offline Completed without error 00% 8164 - #21 Extended offline Completed without error 00% 7422 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thanks in advance
