Networker_77
- Jul 9, 2022
Hi everyone.
I've been running a FreeNAS now TrueNAS server since 2014. Let me say up front that this was my first ever server build, so it does not include recommended hardware.
Yesterday, I received a notification of the error listed in the subject and similar to the one in this post: https://www.truenas.com/community/t...sage-attribute-194-temperature_celsius.77881/. The error concerns my boot drive, which is a 2-year-old Crucial BX500 120GB 3D NAND SATA SSD (CT120BX500SSD1).
Output of -a /dev/ada2:
The other post said that the error was a firmware problem because the drive is an SSD. Is the same thing happening here, or should I worry?
Thanks.
=== START OF INFORMATION SECTION === Model Family: Crucial/Micron Client SSDs Device Model: CT120BX500SSD1 Serial Number: 2038E4107E62 LU WWN Device Id: 0 000000 000000000 Firmware Version: M6CR013 User Capacity: 120,034,123,776 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Jul 9 10:11:06 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0002) Does not save SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0 5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 050 Old_age Always - 13452 12 Power_Cycle_Count 0x0032 100 100 050 Old_age Always - 4 171 Program_Fail_Count 0x0032 100 100 050 Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 050 Old_age Always - 0 173 Ave_Block-Erase_Count 0x0032 100 100 050 Old_age Always - 1 174 Unexpect_Power_Loss_Ct 0x0032 100 100 050 Old_age Always - 2 180 Unused_Reserve_NAND_Blk 0x0032 100 100 050 Old_age Always - 100 183 SATA_Interfac_Downshift 0x0032 100 100 050 Old_age Always - 0 184 Error_Correction_Count 0x0032 100 100 050 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 050 Old_age Always - 0 194 Temperature_Celsius 0x0022 055 048 050 Old_age Always In_the_past 45 (Min/Max 32/52) 196 Reallocated_Event_Count 0x0032 100 100 050 Old_age Always - 0 197 Current_Pending_ECC_Cnt 0x0032 100 100 050 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 050 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 100 100 050 Old_age Always - 0 202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 100 206 Write_Error_Rate 0x002e 100 100 050 Old_age Always - 0 210 Success_RAIN_Recov_Cnt 0x0032 100 100 050 Old_age Always - 0 246 Total_LBAs_Written 0x0032 100 100 050 Old_age Always - 38461451 247 Host_Program_Page_Count 0x0032 100 100 050 Old_age Always - 1201920 248 FTL_Program_Page_Count 0x0032 100 100 050 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported
Thanks.
