Funny I found this post... :)
I also have the same problem...
root@truenas:~# cat /var/log/daemon.log | grep Celsi | grep /dev/sde
Sep 22 09:38:58 truenas smartd[5419]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 59 to 60
Sep 22 09:55:34 truenas smartd[5206]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 59
Sep 22 10:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 59 to 56
Sep 22 11:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 55
Sep 22 15:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 22 16:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 22 17:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 22 18:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 22 19:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 56
Sep 22 20:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 55
Sep 23 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 23 07:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 23 12:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 23 14:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 23 17:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 23 17:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 24 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 24 04:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 24 04:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 24 07:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 24 12:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 24 14:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 51
Sep 25 01:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 01:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 25 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 02:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 03:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 04:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 04:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 05:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 05:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 06:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 06:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 07:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 25 12:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 12:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 25 13:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 13:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 14:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 25 18:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 18:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 25 19:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 25 21:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 25 21:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 25 21:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 26 00:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 00:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 26 00:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 26 01:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 01:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 26 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 02:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 03:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 03:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 48
Sep 26 04:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 04:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 48 to 50
Sep 26 04:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 05:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 05:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 06:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 06:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 07:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 07:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 26 15:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 26 15:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 26 15:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 27 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 27 03:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 04:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 04:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 05:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 05:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 06:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 06:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 07:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 27 15:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 15:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 27 16:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 16:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 17:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 17:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 18:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 18:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 19:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 19:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 27 20:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 20:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 27 20:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 21:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 21:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 27 22:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 22:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 27 23:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 27 23:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 00:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 00:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 01:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 01:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 48
Sep 28 02:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 03:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 03:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 04:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 04:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 05:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 05:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 06:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 06:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 07:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 07:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 08:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 08:30:33 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 09:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 28 09:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 48 to 50
Sep 28 09:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 53
Sep 28 10:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 63
Sep 28 15:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 60
Sep 28 16:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 56
Sep 28 17:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 55
Sep 28 19:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Sep 29 01:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 51
Sep 29 07:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 53
Sep 30 02:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 51
Sep 30 04:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 30 04:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 50
Sep 30 04:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], Failed SMART usage Attribute: 194 Temperature_Celsius.
Sep 30 05:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 50 to 51
Sep 30 07:00:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 51 to 53
Sep 30 09:00:33 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
Sep 30 09:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 53
Oct 1 08:30:32 truenas smartd[33001]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 55
root@truenas:~# smartctl /dev/sde -a
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.42+truenas] (local build)
Model Family: Crucial/Micron Client SSDs
Device Model: CT120BX500SSD1
Serial Number: 2049E4159FEC
LU WWN Device Id: 0 000000 000000000
Firmware Version: M6CR013
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
ATA Version is: ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Oct 1 11:26:37 2021 CEST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
been run.
data collection: ( 120) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 1
1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 050 Old_age Always - 3441
12 Power_Cycle_Count 0x0032 100 100 050 Old_age Always - 49
171 Program_Fail_Count 0x0032 100 100 050 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 050 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 100 100 050 Old_age Always - 1
174 Unexpect_Power_Loss_Ct 0x0032 100 100 050 Old_age Always - 19
180 Unused_Reserve_NAND_Blk 0x0032 100 100 050 Old_age Always - 100
183 SATA_Interfac_Downshift 0x0032 100 100 050 Old_age Always - 0
184 Error_Correction_Count 0x0032 100 100 050 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 050 Old_age Always - 0
194 Temperature_Celsius 0x0022 053 041 050 Old_age Always In_the_past 47 (Min/Max 29/59)
196 Reallocated_Event_Count 0x0032 100 100 050 Old_age Always - 0
197 Current_Pending_ECC_Cnt 0x0032 100 100 050 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 050 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 050 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 100
206 Write_Error_Rate 0x002e 100 100 050 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 050 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 050 Old_age Always - 103304406
247 Host_Program_Page_Count 0x0032 100 100 050 Old_age Always - 3228262
248 FTL_Program_Page_Count 0x0032 100 100 050 Old_age Always - 184320
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 3441 -
Selective Self-tests/Logging not supported
