BloodyBonkers
- Sep 17, 2017
I ran a burn in script on the new ssd intended as a boot drive for my grandparents future FreeNAS box ;) using this script from github "Spearfoot/disk-burnin-and-testing".
What I ended up with after the script completed was an alert from freenas giving me this message: "Device: /dev/ada3, Failed SMART usage Attribute: 194 Temperature_Celsius."
Reading from the smart data the highest reported temperature was 62c, and the specified operating temperature range listed by crucial is 0-70c.
Seeing as the temperature was within that range, why did I get an alert?
Should I be worried and think about replacing it, or can I start using the ssd and expect it to work fine.
Here's the output from smartctl -a /dev/ada3:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: CT240BX500SSD1 Serial Number: XXXXXXXXXXX LU WWN Device Id: 0 000000 000000000 Firmware Version: M6CR013 User Capacity: 240,057,409,536 bytes [240 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sun Sep 29 17:40:26 2019 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0002) Does not save SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0 5 Reallocated_Sector_Ct 0x0032 100 100 010 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 050 Old_age Always - 19 12 Power_Cycle_Count 0x0032 100 100 050 Old_age Always - 3 171 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 0 173 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 14 174 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 0 180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 050 Old_age Always - 100 183 Runtime_Bad_Block 0x0032 100 100 050 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 050 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 050 Old_age Always - 0 194 Temperature_Celsius 0x0022 068 038 050 Old_age Always In_the_past 32 (Min/Max 29/62) 196 Reallocated_Event_Count 0x0032 100 100 050 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 050 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 050 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 100 100 050 Old_age Always - 0 202 Unknown_SSD_Attribute 0x0030 100 100 001 Old_age Offline - 100 206 Unknown_SSD_Attribute 0x002e 100 100 050 Old_age Always - 0 210 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 0 246 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 1875448512 247 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 58607766 248 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 57839616 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 5 - # 2 Short offline Completed without error 00% 4 - # 3 Extended offline Completed without error 00% 0 - # 4 Short offline Completed without error 00% 0 - Selective Self-tests/Logging not supported
