This post https://forums.freenas.org/index.ph...g-of-services-s-m-a-r-t-information-go.63205/
I know this IS WRONG. There is a small chance that the numbers may be Fahrenheit, but 116F is 46.66667C
Box is almost completely idle and has been so for most of the day. I have a script that does smartctl and my drives are all WAY below.
I've NEVER seen one of these WD drives that hot even after several hours of scrubbing (the heaviest load they ever see)! Hottest I've seen is about 42-43 during a hot summer and during a scrub.
I haven't looked at the code, but a bit of quick messing with a calculator makes me think someone messed up the C->F conversion
°F = ℃ × 1.8 + 32 ... just a guess, but it looks like the code may be doing something like °F = (℃ + 32) × 1.8
If someone wants more info for troubleshooting, please let me know.
prompted me to have a peek in the log just for interest and I found: (recent example for /dev/da4)I have found it. The messages were written to
Code:/vat/log/daemon.log
Apr 18 14:52:47 freenas smartd[3480]: Device: /dev/da3 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 115 to 116 Apr 18 15:22:46 freenas smartd[3480]: Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 116 to 115 Apr 18 15:52:46 freenas smartd[3480]: Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 115 to 116 Apr 18 16:22:46 freenas smartd[3480]: Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 116 to 115 Apr 18 16:52:46 freenas smartd[3480]: Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 115 to 116
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68MYMN1 Serial Number: WD-WXXXXXXXXXXXXXX LU WWN Device Id: 5 0014ee 2b6647874 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Apr 18 16:53:58 2018 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 2144) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 675) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 210 196 021 Pre-fail Always - 8458 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 629 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 22704 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 68 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 27 193 Load_Cycle_Count 0x0032 192 192 000 Old_age Always - 24384 194 Temperature_Celsius 0x0022 116 097 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
da0 ATA WDC WD60EFRX-68L 37C da1 ATA WDC WD60EFRX-68L 35C da2 ATA WDC WD60EFRX-68M 34C da3 ATA WDC WD60EFRX-68M 36C da4 ATA WDC WD60EFRX-68M 36C da5 ATA WDC WD60EFRX-68M 34C da6 ATA WDC WD60EFRX-68L 36C da7 ATA WDC WD60EFRX-68L 35C
