Krowvin
- Jul 24, 2014
This might be helpful when installing other plugins as well.
Someone might have the same troubles I was having so I thought I might create a post to help out. Who knows, maybe i'll stumble upon my own post later on when trying to set this up again!
If you want to access HeadPhones from yourdomain.com/headphones or localIP/headphones then you might find this useful.
Like sickrage, couchpotato, and sabnzbd there are a few different configuration settings you need to do in order to get it completely up and running.
HeadPhones doesn't seem to have a setting in the client to set the web root, which means you'll have to go to the config file to change it.
[TIME SAVER] Add your headphones jail to the sabnzbd jail, you can download the plugin here:
http://download.freenas.org/plugins/9/x64/
be sure to get the newest version of headphones
then, on the FreeNAS GUI you can click:
- Jails > (Jail name with other plugins) > upload plugin (looks like a brown box) ... Wait, BOXES ARE BROWN? Yeah, well XD
- Navigate to where you downloaded the plugin on your local system.
1) Turn off the headphones plugin:
inside the headphones jail (see appendix A. at bottom of post)
Note: Don't stop the jail, just the plugin
2) Edit the headphones config file
(If you don't have nano you can install it, or use another text editor see appendix B.)
still inside the headphones jail type:
Search for the webroot line: Press CTRL + W and type http_root
The line should look like this:
assuming you want /headphones as the webroot
press ctrl+x to save and exit
3) Edit the webserver proxy (Assuming NGINX)
I'm not sure on the config for Apache, but here it is for NGINX
inside the webserver jail, navigate to your nginx config and edit it. That might look like this:
Inside the server block add this:
This assumes the headphones plugin is inside the webserver jail.
restart NGINX:
4) If you are using scripts to auto process headphones, we will need to edit the script file.
If you're using Joshua's guide for plugins (Sickrage, couchpotato, sab, transmission) you might find the scripts saved here:
(THANKS JOSHUA!)
If you don't make this change, you might see an error in your sabnzbd GUI similar to this one:
Exit(1) HeadPhones: Failed to post-process - Server returned status 404!
inside your SABNZBD jail (Where the scripts are handled)
press ctrl+w and search for headphones, scroll down a bit and you should see web_root. Change this to:
5) Start the headphones plugin
APPENDIX
A. HOW TO GET INSIDE A JAIL
1) login to the server via ssh or by clicking the command line on the freenas GUI
2)list the jails
take note of the jail ID (JID)
3) enter the jail
B. HOW TO INSTALL NANO
Enter the jail per Appendix A.
accept conditions to install
Hopefully this helps someone!
service headphones stop
nano /var/db/headphones/config.ini
http_root = /headphones
nano /usr/local/etc/nginx/nginx.conf
location ^~ /headphones { proxy_pass http://127.0.0.1:8181; }
restart NGINX:
service nginx restart
(THANKS JOSHUA!)
nano /usr/local/share/nzbToMedia/autoProcessMedia.cfg
web_root = /headphones
service headphones start
APPENDIX
2)list the jails
jls
3) enter the jail
jexec jailID csh
pkg install nano
