FN 11.0 - Problems with Headphones
Yakje
Version: FreeNAS-11.0-U4
Guide i "kind of" used: Headphones setup guide
So after ditching Freenas Corral, which i had grown quite fond of tbh. I am now trying to get everything setup in FreeNAS 11.0.
Till now i have setup Plex, Sabnzbd, Sonarr & Radarr, all running in a generic jail (i am not using the Plugins)
As i was trying to do the same for "Headphones" i ran into a problem, whenever i try to run the command service headphones start the following error pops up:
/usr/local/etc/rc.d/headphones: WARNING: run_rc_command: cannot run /config/Headphones.py
My headphones RCfile:
#!/bin/sh
# PROVIDE: headphones
# REQUIRE: DAEMON
# BEFORE: LOGIN
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf.local or /etc/rc.conf
# to enable this service:
# headphones_enable (bool): Set to NO by default.
# Set it to YES to enable it.
# headphones_user: The user account Headphones daemon runs as what
# you want it to be. It uses '_sabnzbd' user by
# default. Do not sets it as empty or it will run
# as root.
# headphones_dir: Directory where Headphones lives.
# Default: /usr/local/headphones
# headphones_pid: The name of the pidfile to create.
# Default is headphones.pid in headphones_dir.
. /etc/rc.subr
name="headphones"
rcvar=${name}_enable
load_rc_config ${name}
: "${headphones_enable:="NO"}"
: "${headphones_user:="headphones"}"
: "${headphones_dir:="/usr/local/headphones"}"
: "${headphones_conf:="/usr/local/headphones/config.ini"}"
command="${headphones_dir}/Headphones.py"
command_interpreter="/usr/local/bin/python"
pidfile="/var/run/headphones/headphones.pid"
start_precmd="headphones_start_precmd"
headphones_flags="--daemon --nolaunch --pidfile $pidfile --config $headphones_conf $headphones_flags"
headphones_start_precmd() {
if [ $($ID -u) != 0 ]; then
err 1 "Must be root."
fi
if [ ! -d /var/run/headphones ]; then
install -do $headphones_user /var/run/headphones
fi
run_rc_command "$1"
I am not sure why it is not able to start, since i did execute the command:
chmod +x /usr/local/etc/rc.d/headphones
, any ideas on this matter are highly appreciated!
Redcoat
"service headphones start"?
Yakje
Yakje
Anyone who might know how to fix it?
I guess it has something to do with the RCfile, but unfortunately im not that experienced with these kind of files to figure it out on my own. No clue what to add/edit
