bcknapp
- Dec 28, 2014
Hi, I'm very new to the FreeNAS system and this is my first post in the community. The hardware details of my setup are listed below. I installed the Crashplan plugin following some of the instructions in these videos: ,
I edited /usr/pbi/crashplan-amd64/share/crashplan/conf/my.service.xml line 24 and changed <servicehost> to 0.0.0.0 to listen to any IP address. I then edited C:\Program Files\CrashPlan\conf\ui.properties to point the Crashplan client to point to the IP address of the jail in which crashplan is installed. Also, not sure if it matters but I also did the following command as recommended by the guide I followed: /usr/bin/cpuset -l 0 /usr/local/share/crashplan/bin/CrashPlanEngine restart. This configuration worked initially and I was able to sign in, choose the folders for backup (after adding jail storage points), and backup progress was working great... until my first reboot. After reboot, in the Plugins > Installed section, the crashplan Service status button is turned off and will not turn on when I click on it. I used the shell for the jail in the WebGUI and attempted to restart the crashplan service using "service crashplan stop && service crashplan start" but no luck. I am unable to connect via the Crashplan client on my PC. One thing I noticed is that when I run the command sockstat -l I get a very short list with no mention of Java when compared to running the command shortly after the successful installation.
I have deleted the plugin (apparently this deletes the jail as well) and have redone this entire process now 3 times, and everytime I reboot the freeNAS system, I get the exact same problem.
Being incredibly new to the community I have not been able to find anything that seems to relate to this problem either in these forums or on Google. If anyone could point me in the right direction, I would greatly appreciate it!
Brian
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS root python2.7 5701 3 tcp4 192.168.1.2:12355 *:* root cron 5473 4 dgram -> /var/run/logpriv root syslogd 5405 4 dgram /var/run/log root syslogd 5405 5 dgram /var/run/logpriv root syslogd 5405 6 udp6 *:514 *:* root syslogd 5405 7 udp4 *:514 *:*
Brian
