petr
- Jun 13, 2013
With great hope and anticipation, I've fetched the crashplan plugin offered in my UI (version 3.5.3). Install went seamingly well, after jail got created I've clicked the plugin's menu and confirmed the licnese.
Then, I went and set up ssh login into jail (needed to enable root login & password login in sshd_conf).
So far so good.
However, I cannot seem to be able to connect! The crashplan process seems to be running, however, netstat does not list it any corresponding LISTEN ports!
I've tried numerous way to start the crashplan via its launch agents to no avail.
Are there any special steps that need to be taken in order to make the plugin work?
So far so good.
