Hi guys,
I'm trying to build a distributed highly available storage pool.
My systems are 3x TrueNAS-SCALE-21.07-MASTER-20210707-192920 and TrueCommand Master-20210707.
I was able to create a replicated volume via the UI - nice and easy:
The bricks are hidden on the nodes, but that wasn't much of a roadblock.
My next step was to create a volume called "gluster" on each node using SSH:
I managed to mount it on either node using
And verified replication via
But now I'm stuck. The documentation I'm following suggests to to use CTDB to create the virtual IP which I need for the client, but this doesnt work on Scale.
Did anyone had a play with this and could point me towards my next step?
Thanks a lot,
Sascha
mount -t glusterfs ...
touch file01 file02 file03
Thanks a lot,
Sascha
