Clustering Storage for HA
sasch
Hi guys,
I'm trying to build a distributed highly available storage pool.
My systems are 3x TrueNAS-SCALE-21.07-MASTER-20210707-192920 and TrueCommand Master-20210707.
I was able to create a replicated volume via the UI - nice and easy:
The bricks are hidden on the nodes, but that wasn't much of a roadblock.
My next step was to create a volume called "gluster" on each node using SSH:
I managed to mount it on either node using
mount -t glusterfs ...
And verified replication via
touch file01 file02 file03
But now I'm stuck. The documentation I'm following suggests to to use CTDB to create the virtual IP which I need for the client, but this doesnt work on Scale.
Did anyone had a play with this and could point me towards my next step?
Thanks a lot,
Sascha
