Unable to create cluster volume.
rtrombetta
Hello guys!
I´m trying to add a cluster volume into a 3 node system. I just installed Truenas Scale into 3 VMs and a VM with TrueCommand (just for testing purposes). All 3 nodes are usingstatic IP addresses and were added into TrueCommand. I can browse and edit all 3 nodes using TrueCommand.
When I click to add a new cluster volume, the "next" button is disabled. I can select all 3 node in the brick choices but the next button remains disabled. I´m missing something ?
Thank You!
You didn't name it.
rtrombetta
You didn't name it.
Thanks for the answer!
Sorry, I hadn't seen that the image I captured had the volume without the name, but anyway, even completing everything the "next" button remains disabled. As this is my first time using TrueCommand and I am not familiar with it, I would like to know if it is necessary to do some kind of license activation or something similar to activate these functions.
Thank You!
No. I was able to get the next button to go blue just by filling in the name after having set enough bricks at the bottom.
I see that with Distributed replicated (you seem to have selected that) that the minimum bricks is 4 to allow that to proceed (i.e. set a replica count of 2).
rtrombetta
Thank you very much. I was trying to create a cluster volume with 3 nodes...
