TrueCommand Clustering not working with three-part domain name
JanC4B
I have a Problem with the clustering Process of TrueCommand.
I installed 3 TrueNAS Scale Nodes and wanted to create a cluster with them.
I installed the TrueCommand docker image on a VM.
In the process of creating a cluster, at the step where i have to join them to my Domain, I get an error, which says that my domainname is not accepted.
Our Domainname has 3 parts, e.g. xxx.yyy.zzz, is this a known Problem and is there a workaround?
Are you saying you tried with a 2-part domain and it does work?
I suspect you could supply the NETBIOS domain name...
JanC4B
If I just enter the 2nd +3rd part or 1st+2nd it doesnt show the error message.
I tried to enter the NETBIOS-Name but it still shows the error message.
OK, sounds like a bug then... "Report a Bug" at the top of this page.
