TrueNAS-13.0-U1
11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz
32 GB of RAM
6x 5,46 TB Seagate IronWolfs in RAIDZ2 with 1TB NVME CASH drive
Every HDD show 6 Checksum errors and zpool status shows
SMART test shows no errors, I just paste one of them, the rest seems similar:
Do I need to worry?
32 GB of RAM
pool: ciasta_01 state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub in progress since Mon Jul 18 18:31:30 2022 2.73T scanned at 2.80G/s, 906G issued at 930M/s, 6.63T total 0B repaired, 13.34% done, 01:48:02 to go config: NAME STATE READ WRITE CKSUM ciasta_01 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/6766691e-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 gptid/676e8d22-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 gptid/675d7896-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 gptid/6781d8c1-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 gptid/6779b133-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 gptid/674d74d5-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 6 cache gptid/6626ee23-dd0f-11ec-863f-d85ed3a1c817 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: ciasta_01/Backup@auto-2022-07-10_16-30:/domain/domainD2022-07-09T230031_B681.vbk
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate IronWolf Device Model: ST6000VN001-2BB186 Serial Number: *************** LU WWN Device Id: 5 000c50 0dbc15d43 Firmware Version: SC60 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5425 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Jul 18 18:50:21 2022 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 721) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 074 064 006 Pre-fail Always - 24158792 3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 14 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 073 060 045 Pre-fail Always - 21622516 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1275 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 root@NASOLSZA[~]# 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 067 064 040 Old_age Always - 33 (Min/Max 20/36) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 49 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 65 194 Temperature_Celsius 0x0022 033 040 000 Old_age Always - 33 (0 20 0 0 0) 195 Hardware_ECC_Recovered 0x001a 074 064 000 Old_age Always - 24158792 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1273h+48m+42.788s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3524124356 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 14427495997 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 1233 - # 2 Extended offline Completed without error 00% 1165 - # 3 Short offline Completed without error 00% 1065 - # 4 Short offline Completed without error 00% 897 - # 5 Short offline Completed without error 00% 729 - # 6 Short offline Completed without error 00% 560 - # 7 Short offline Completed without error 00% 392 - # 8 Short offline Completed without error 00% 224 - # 9 Short offline Completed without error 00% 57 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Do I need to worry?
