sector error in gui, nothing in cli
My truenas (formaly freenas ) has been telling me that one drive has unrecoverable errors in the gui, using alerts. But the in the cli, for zpool, everything is swell and smarctl does not show anything. Where is this alert coming from ? Should I believe the alert and change the drive ?
simonpie@sancy:~ % zpool status
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
    still be used, but some features are unavailable.
    the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:01:46 with 0 errors on Tue Feb 16 03:46:46 2021
    NAME          STATE     READ WRITE CKSUM
    freenas-boot  ONLINE       0     0     0
      ada2p2      ONLINE       0     0     0
errors: No known data errors
  pool: tank
 state: ONLINE
  scan: scrub repaired 0B in 21:27:00 with 0 errors on Sun Jan 24 21:27:02 2021
    tank                                            ONLINE       0     0     0
      raidz2-0                                      ONLINE       0     0     0
        gptid/5151914b-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/525f65f1-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/5373fb97-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/549a6e7f-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/55b311a9-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/56d8dfa9-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/581bb732-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
        gptid/593fbdff-4507-11e8-aba9-d05099c39e7c  ONLINE       0     0     0
    cache
      gptid/c9dd29e4-83f1-11ea-86ca-d05099c39e7c    ONLINE       0     0     0
simonpie@sancy:~ % sudo smartctl -a /dev/ada5
Password:
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST10000VN0004-1ZD101
Serial Number:    ZA24TDYF
LU WWN Device Id: 5 000c50 0afd9085a
Firmware Version: SC60
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Feb 19 19:36:30 2021 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      ( 113)    The previous self-test completed having
                    the read element of the test failed.
data collection:         (  567) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 855) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x50bd)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   080   064   044    Pre-fail  Always       -       107021960
  3 Spin_Up_Time            0x0003   088   086   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       28
  5 Reallocated_Sector_Ct   0x0033   097   097   010    Pre-fail  Always       -       13814
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       929614754
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       22446 (96 171 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       29
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   086   000    Old_age   Always       -       236226805815
189 High_Fly_Writes         0x003a   053   053   000    Old_age   Always       -       47
190 Airflow_Temperature_Cel 0x0022   067   056   040    Old_age   Always       -       33 (Min/Max 28/38)
191 G-Sense_Error_Rate      0x0032   079   079   000    Old_age   Always       -       42489
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       34
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1358
194 Temperature_Celsius     0x0022   033   044   000    Old_age   Always       -       33 (0 19 0 0 0)
195 Hardware_ECC_Recovered  0x001a   021   001   000    Old_age   Always       -       107021960
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       24
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       24
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       22403 (86 189 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       40501961212
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       247594940649
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed: read failure       10%     20828         -
# 2  Extended offline    Completed without error       00%     14330         -
simonpie@sancy:~ %
Redcoat
?? Your Smart test log shows a read failure:
