I'm having trouble with my TrueNAS Installation. It has historically been a Freenas (... back in the days of FreeNAS 11), which worked wonderful for the last years. With freeNAS 11 I've managed to copy and read easily around 90-100mb/s from and to the NAS on SMB, AFP, or RSYNC.
However, I've noted that as of lately, no matter what I do, I can't seem to achieve those speeds anymore but instead am limited to 4-11mb/s. I've searched around the forum, but unlike most others both read and writes are slow (and non of the there-mentioned solutions seemed to help).
Since it's slow on RSYNC as well as SMB or AFP, I think I can rule these as culprits out. So this lead me to two conclusions: Harddrive failure or networking problem.
However, it seems to be none of these two options - iperf3 shows the full gigabit connection speed, so it likely is not a networking issue. Harddrive SMART Values look fine, do a periodic selftest (and complete them successfully without errors), so I decided to remove one drive from the pool and readd it again. The result had been a resilvering tasks with 2.4TB of data, which completed in about 9 hours, leading to an average of 73mb/s when resilvering, so I think it's safe to rule that one too out.
Does anyone have a clue, what could possibly be any other culprit?
My system specs are as follows:
Motherboard: Gigabyte H87-HD3
CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GH
RAM: 4*8GB DDR3 -> 32GB total
HDD: 2* 4TB WD RED (Mirrored)
Systemload is usually pretty idle, as this is my personal NAS device, nothing with lots of users or something.
TrueNAS Version: 12.0-U4.1
Thanks in advance!
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E1620954
LU WWN Device Id: 5 0014ee 2b4c4b086
Firmware Version: 80.00A80
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Aug 3 15:00:17 2021 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (53520) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 535) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 175 175 021 Pre-fail Always - 8208
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 96
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 014 014 000 Old_age Always - 63325
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 40
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 182 182 000 Old_age Always - 55470
194 Temperature_Celsius 0x0022 110 103 000 Old_age Always - 42
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 63274 -
# 2 Short offline Completed without error 00% 63166 -
# 3 Short offline Completed without error 00% 62999 -
# 4 Short offline Completed without error 00% 62831 -
# 5 Short offline Completed without error 00% 62663 -
# 6 Extended offline Completed without error 00% 62530 -
# 7 Short offline Completed without error 00% 62447 -
# 8 Short offline Completed without error 00% 62279 -
# 9 Short offline Completed without error 00% 62112 -
#10 Short offline Completed without error 00% 61944 -
#11 Extended offline Completed without error 00% 61813 -
#12 Short offline Completed without error 00% 61704 -
#13 Short offline Completed without error 00% 61536 -
#14 Short offline Completed without error 00% 61368 -
#15 Short offline Completed without error 00% 61200 -
#16 Extended offline Completed without error 00% 61068 -
#17 Short offline Completed without error 00% 60984 -
#18 Short offline Completed without error 00% 60817 -
#19 Short offline Completed without error 00% 60649 -
#20 Short offline Completed without error 00% 60481 -
#21 Extended offline Completed without error 00% 60349 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
Serial Number: WD-WCC4E1628473
LU WWN Device Id: 5 0014ee 25f6efbb5
Local Time is: Tue Aug 3 15:03:08 2021 CEST
was never started.
been run.
data collection: (52080) seconds.
command.
power-saving mode.
recommended polling time: ( 521) minutes.
3 Spin_Up_Time 0x0027 179 179 021 Pre-fail Always - 8041
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 106
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 2
9 Power_On_Hours 0x0032 014 014 000 Old_age Always - 63326
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 184 184 000 Old_age Always - 49366
194 Temperature_Celsius 0x0022 113 106 000 Old_age Always - 39
No Errors Logged
# 2 Short offline Completed without error 00% 63167 -
# 5 Short offline Completed without error 00% 62664 -
# 7 Short offline Completed without error 00% 62448 -
# 8 Short offline Completed without error 00% 62280 -
# 9 Short offline Completed without error 00% 62113 -
#12 Short offline Completed without error 00% 61705 -
#13 Short offline Completed without error 00% 61537 -
#14 Short offline Completed without error 00% 61369 -
#15 Short offline Completed without error 00% 61201 -
#16 Extended offline Completed without error 00% 61069 -
#17 Short offline Completed without error 00% 60985 -
#19 Short offline Completed without error 00% 60650 -
#20 Short offline Completed without error 00% 60482 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Thanks in advance!
