Hi, I need some help with understanding this S.M.A.R.T. "situation" on the boot SSD.
I got the scary message in the console:
But the tests (short/long) pass and I don't understand which is the metric that is triggering this alert. Infact it says:
Could someone help me?
FAILED SMART self-check. BACK UP DATA NOW!
No failed Attributes found.
root@host: smartctl -a /dev/ada3 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Crucial/Micron Client SSDs Device Model: CT240BX500SSD1 Serial Number: 2028E4076B04 LU WWN Device Id: 0 000000 000000000 Firmware Version: M6CR022 User Capacity: 240,057,409,536 bytes [240 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Oct 13 11:36:19 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. No failed Attributes found. General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0002) Does not save SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 000 100 000 Pre-fail Always - 0 5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2501 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 491 171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0 172 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0 173 Ave_Block-Erase_Count 0x0032 001 001 000 Old_age Always - 35 174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 77 180 Unused_Reserve_NAND_Blk 0x0033 100 100 000 Pre-fail Always - 227 183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 0 184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 067 043 000 Old_age Always - 33 (Min/Max 9/57) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_ECC_Cnt 0x0032 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0 202 Percent_Lifetime_Remain 0x0030 099 099 001 Old_age Offline - 1 206 Write_Error_Rate 0x000e 000 000 000 Old_age Always - 0 210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0 246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 4150537437 247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 129704294 248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 177253984 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 2476 - # 2 Short offline Completed without error 00% 2452 - # 3 Short offline Completed without error 00% 2428 - # 4 Short offline Completed without error 00% 2404 - # 5 Short offline Completed without error 00% 2379 - # 6 Short offline Completed without error 00% 2355 - # 7 Short offline Completed without error 00% 2331 - # 8 Short offline Completed without error 00% 2307 - # 9 Short offline Completed without error 00% 2283 - #10 Short offline Completed without error 00% 2259 - #11 Short offline Completed without error 00% 2235 - #12 Short offline Completed without error 00% 2211 - #13 Short offline Completed without error 00% 2187 - #14 Short offline Completed without error 00% 2163 - #15 Short offline Completed without error 00% 2140 - #16 Short offline Completed without error 00% 2116 - #17 Short offline Completed without error 00% 2092 - #18 Short offline Completed without error 00% 2068 - #19 Short offline Completed without error 00% 2044 - #20 Short offline Completed without error 00% 2020 - #21 Short offline Completed without error 00% 1996 - Selective Self-tests/Logging not supported
