Sirach Matthews
 - Sep 23, 2014
Brief History
My FreeNAS server has been running fine, fairly consistently over the past 5 years or so on my home-built server. Recently, it suffered MB failure. Because it was 5 years old, they don't make them with the same CPU socket, so I ended up replacing everything except the PSU, case and HDDs. I was able to get things back up and running, however; the new MB only has two USB 2.0 ports available. With one of those pots being used up by my boot drive, that left me with a single USB 2.0 port for my external devices, such as my UPS and 3D printer. Anticipating this issue, I purchased a USB 3.0 drive, so that I could migrate the boot drive to it, thus freeing up all USB 2.0 ports.
What I've Tried
Suggestions?
Acknowledging that I do not know everything, I am seeking the sage wisdom and advice from the community, whom I see as a vast resource of knowledge and skill far surpassing my own. Any help or advice you are able to apply would be very much appreciated.
What I've Tried
- Fresh Install & Config UL
- Save the configuration while booted from the USB 2.0 drive.
 - Installed fresh FreeNAS-9.10.2-U6 to the USB 3.0 drive.
 - Booted using the USB 3.0 drive.
 - Attempted to upload configuration file created in step 1 - Error.
- Mirroring USB 2.0 boot drive to USB 3.0 drive
- WebGUI: System -> Boot -> Status
 - Selected freenas-boot
 - Clicked Attach
 - Selected the USB 3.0 disk as the member disk
 - Clicked Attach Disk - Error - Device too small.
Suggestions?
