can't use the gui
darkzwesjel
I'm new to freenas.
I tried at home to access freenas and that worked a bit.
but now i moved the pc to my gf home and i cant use the gui anymore
I already did a factory reset and a gui reset.
in the attached file you can see how the gui looks now.
if i go to account and try to change the admin and set a password it will not save the entered values.
also it does not respond to other command like creating an volume.
(also i cant open it in firefox so i need to use IE)
thx in advance
warri
The missing tree view to the left is a known bug with IE 10.
Use Firefox or Chrome.
If you want more specific help, follow the forum rules: post your hardware specs and a detailed error description (i.e. for Firefox).
darkzwesjel
okay when i lived at home like a week ago i could use firefox now i'm terrorizing my gf :) i cant acces it in firefox. i'm hooked up bij the same d-link router.
  • FreeNAS version and platform (32 or 64 bit).
i'm running 9.1.1 a 64 bit version (from the website from last week of october +-)
  • General hardware information (CPU, RAM, Motherboard model, etc.).
normaly it aint a hardware problem cause it worked fine with the tree at my home. you can also see that the basic configuration is a core 2 duo processor ant 2 Gb of ram dont know the brand of motherboard. need to open the pc again for it. for the hdd it are 2x2tb (think it were barracuda green came frome my lacie nas where the firmeware died :) ) als i'm booting it from the usb now i also have a hdd install butt it didn't work anymore with that so i also tried a 8 gb usb drive but same result
  • Specific hardware information (Network card chipset, Raid controller chipset, etc.).
  • DMESG output or copy of specific error message.
i don't see an error really. so cant give a report. the only thing fire fox says i can't load the page see picture
  • IFCONFIG output if you are asking about a NIC or networking problem.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\darkzwesjel>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : home
Link-local IPv6 Address . . . . . : fe80::95f7:703a:56aa:5b0f%11
IPv4 Address. . . . . . . . . . . : 192.168.0.156
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Tunnel adapter isatap.home:
Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:c78:10de:b1ea:3cf9
Link-local IPv6 Address . . . . . : fe80::c78:10de:b1ea:3cf9%13
Default Gateway . . . . . . . . . : ::
this is my ping test
C:\Users\darkzwesjel>ping 192.168.0.135
Pinging 192.168.0.135 with 32 bytes of data:
Reply from 192.168.0.135: bytes=32 time=1ms TTL=64
Reply from 192.168.0.135: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.0.135:
Packets: Sent = 4, Received = 4, Lost = 0 (0%
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
  • Code snippets, logs, config files and quotes should be enclosed in the appropriate bbcode tags.
  • To provide you with accurate answers we need this information and it will also help others to find your posts when they are searching for similar information.
i hope i provided enough info so you can help me out of this situation. and if i'm out of it i already have a second qeusting about the premissions cause i could figure it out with the forums. but thats for later first get it back in working condition.
grtz
warri
You are right, this doesn't look like a hardware problem.
Try to connect to http://192.168.0.135 with Firefox (not HTTPS!). In your IE screenshot you are using HTTP. If https is not configured, you will not be able to access the GUI through https.
darkzwesjel
i also saw that. but if i try that one it automatic add an S to it.
i did't change settings in between. so its weird that I access it, i didn't watched if it was http or https in the past
darkzwesjel
okay i solved the problem.
i've downloaded chrome an i changed the settings to https. (couldn't change it with ie)
now i can acces it back in firefox :)
thx for the answers
