Can't resolve hostnames within my jails
zimon
I recently moved my freenas to a different network and therefore I had to change the ip adresses of all my jails (from 192.168.188.x to 192.168.1.x)
Unfortunalty I can't ping any internet adress anymore within any of my jails.
When I try
ping google.com
I get
ping: cannot resolve google.com: Host name lookup failure
Pinging 8.8.8.8 works fine.
Anyone any ideas?
D
dlavigne
Guest
Does netstat -rn within the jail show the correct default gateway?
zimon
no it didn't.
I am stupid.
I changed it in /etc/resolve.conf
it works now
D
dlavigne
Guest
I assume you mean /etc/rc.conf for the gateway, so you won't be disappointed at next boot :smile:
Ixian
I think /etc/rc.conf is just the default fallback, sounds like @zimon doesn't have the gateway/dns configured correctly in the GUI: Network>Global Configuration. Those are stored in the Freenas config db, which over-write default.conf values if the values are present in it. That's the better way to do it I think.
Changes to /etc/resolv.conf inside the jail itself will, as @dlavigne pointed out, reset on next boot.
zimon
thanks, you are right, those settings are not set.
since my gateway (my router on 196.168.1.1) is already configured to use 1.1.1.1 as a nameserver should I put 196.168.1.1 in all settings in the GUI>network>Global configuration?
For ipv4 gateway and nameserver?
Ixian
Yes, that's generally the way to do it if you have DNS resolving set up on your router; assuming that is the DNS all your other devices use then your Freenas server should be consistent with them. You can always add a secondary DNS to Freenas as a backup. If you do any kind of network ad blocking (like a Pi-hole, or PFBlockerNG with pfsense, etc.) then you always want to just use it.
By the way if you've never looked in to it consider a network-wide adblocker, they are pretty awesome. Different topic though.
zimon
Thats anawesome idea :) will set it on my todo list :)
