Can not access Plex Web UI -Connection refused
Sabot68
HI,
I have solved the issue, looks like there is a bug with either the current release of truenas of the plex plugin, there have been many threads open about similar issues. I found the fix that worked for me, Installed the plugin with NAT selected then had to forward some ports to get the manage link to work. Thanks to bundlepax for posting the fix in another thread
scooby622
HI,
can you link to the fix, I am also brand new to truenas and seem to be having the exact issue as you.
eljose
I've had the same issue. What fixed it for me was going to the plex jail settings (turn it off before editing), enable NAT in the Basic Properties, enabling NAT Port Forwarding in Network Properties and adding an entry as shown in the image below.
Hope that helps somebody with the same problem :)
