Greetings!
Ok so with reference to my previous post, I had an issue with a drive on my pool. Turns out it wasn't the drive at fault. It was a dual failure of both the sata port AND the cable. Go figure?
However, my data is safe. I know I'm going to get "where's your redundancy?" and to be honest, at the moment having backups on other machines means the only thing I'll lose is time rebuilding the pool and it'll also provide experience to me being a ZFS newbie.
That said, I was able by some research and sheer luck preserve the data on the pool and everything is still running happily and is even happily now serving as a DNS sinkhole with pi-hole running on a ubuntu server VM. So until I am able to purchase some new hardware, it's running as I intended from the start, to be a whole home file server and media player with pi hole sucking up as many ads as possible.
So, my question for you all. I currently have an unhealthy pool due to aforementioned issues. Truenas has noted several files with permanent errors. Zpool scrub/clear cannot fix them but no new ones have popped up since I fixed the problem.
Most of them appear to be .log files. Would they be safe to delete and how?
There is an iocage error too. Would that be nigh on impossible to fix?
Either way, this server was a project to dip my toes in to see if this would work for me and aside from the port/cable issue it has done exactly what I want. I plan on building a newer machine in the near future and I will be planning redundancy into it.
Any insight would be appreciated.
