I've installed Plex plugin and works fine
I've installed Ubuntu 21.04 on a VM and installed Pi-Hole to that Ubuntu and works fine.
The problem comes on rebooting the server, Pi-Hole prevents jails from working therefore breaks Plex. If Pi-Hole is set for autostart, Plex and Jails won't work. If I turn off autostart on Pi-Hole and reboot, Plex will work along side Pi-Hole if turned on afterwards. But new jails/plugins can't be created.
Error: PlexBeta had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped PlexBeta due to DHCP failure Partial plugin destroyed
Which is fine unless I want to add plugins later. Anyway, is there a way to delay a VM i.e Pi-hole on Ubuntu until after the Plex plugin starts.
X8DT3-LN4F Motherboard
2x Xeon X5650 2.66ghz 12mb Cache 6.4 GT/s 6-Core CPUs
48GB configured 12x4GB 10600R ECC Registered
6 WD Blue sata 4 TB raid, 1 TB m.2 cache, 480 GB ssd system disk
2x 720w Power Supplies (PWS-721P-1R)
