FreeNAS UI is Unavailable Five Minutes After Reboot
Bageland2000
EDIT:
A few things I noticed:
1. I have the IPMI SEL low space left error. I cleared it by entering
ipmitool sel clear
2. You'll notice if you look closely on that error, that the date/time is wrong. This keeps happening. I temporarily fixed it by changing the time zone, then setting it back to correct zone.
/EDIT
Hello. I am running into an issue all of the sudden were my UI will be inaccessible following a reboot. Everything works fine for about five minutes, then the UI will not respond. SSH is also not responsive. Windows storage shares will remain responsive for about five more minutes, then go unresponsive. Jails/plugins will remain accessible indefinitely. Nothing has changed except a couple days ago I installed my one and only VM running the latest Ubuntu LTS distro with Pi-hole. Everything worked fine for a few days. I've since rebooted, and turned off the VM altogether. The issue still persists.
All hardware/software is in my signature. I'm a novice/intermediate user, so please keep that in mind if you respond. I understand there's likely more info I'll need to provide, so I'm happy to do so if requested. Thanks so much for your time.
Bageland2000
Also, I haven't gotten any notifications that my HDDs are going bad, but I was reading S.M.A.R.T. data and saw this. Is my drive going bad?
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (39600) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 398) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       5
  3 Spin_Up_Time            0x0027   173   172   021    Pre-fail  Always       -       6341
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       160
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   027   027   000    Old_age   Always       -       53914
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       160
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       111
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1445
194 Temperature_Celsius     0x0022   122   108   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     36189         -
# 2  Short offline       Completed without error       00%     36022         -
# 3  Extended offline    Completed without error       00%     36005         -
# 4  Extended offline    Completed: read failure       90%     30926         4191856
# 5  Short offline       Completed: read failure       50%     28946         4191856
# 6  Short offline       Completed: read failure       50%     28778         4191856
# 7  Short offline       Completed: read failure       50%     28610         4191856
# 8  Extended offline    Completed: read failure       90%     28467         4191856
# 9  Short offline       Completed: read failure       50%     28443         4191856
#10  Short offline       Completed: read failure       50%     28275         4191856
#11  Short offline       Completed: read failure       40%     28107         4191856
#12  Short offline       Completed: read failure       40%     27939         4191856
#13  Short offline       Completed: read failure       50%     27771         4191856
#14  Extended offline    Completed: read failure       90%     27723         4191856
#15  Short offline       Completed: read failure       50%     27604         4191856
#16  Short offline       Completed: read failure       50%     27436         4191856
#17  Short offline       Completed without error       00%     27273         -
#18  Short offline       Completed: read failure       50%     27105         4191856
#19  Extended offline    Completed: read failure       90%     27008         4191856
#20  Short offline       Completed: read failure       50%     26936         4191856
#21  Short offline       Completed: read failure       30%     26769         4191856
17 of 17 failed self-tests are outdated by newer successful extended offline self-test # 3
