Andybluejay
 - Jun 25, 2022
I'm getting ready to destroy a pool to change my disk configuration, but I've noticed it has a .system folder present and I'd to know if it is safe to remove.
The folder is located at /mnt/tank/.system but my system dataset is set to be on another pool, flash, but I have no similar folder on flash. I found a thread where someone had a similar issue: https://www.truenas.com/community/threads/system-dataset-is-in-wrong-location.92163/
I'm guessing it is just a remnant of the old system dataset and is safe to delete? tank was the first pool I created so its reasonable that there would have been a system dataset on it at one point.
