Bug: NUT missing file and can't create pid.
gwaitsi
There are two issues with NUT UPS package.
1) NUT is missing the description file in /usr/local/etc/nut/cmdvartab
- a copy from pfsense is enclosed
If I add the file, it is removed upon reboot. How can I make this permanent?
2) Loading upsd causes the below error
fopen /var/db/nut/uspd.pid
  • cmdvartab.zip
Samuel Tai
Are you trying to start NUT from CLI, or via the UPS service?
gwaitsi
I get the two errors during boot i.e. that cmdvartab is missing and missing upsd.pid so that is from the gui config.
for testing to try and debug, i am starting via CLI.
adding the cmdvartab file fixes the error, but the file is removed after reboot
i suspect the upsd.pid is related to permissions? as i see it is also a frequent problem on freebsd
Samuel Tai
OK, both of those errors are cosmetic, and don't affect the functionality of NUT. The actual PID file will have a name in /var/db/nut of <NUT driver>-ups-<UPS name>.pid.
gwaitsi
I appreciate they maybe cosmetic, but the cmdvartab is an easy fix.
I just need to add the file to /usr/local/etc/nut except truenas keeps removing it.
from boot for the pid file, i see /var/db/nut/
upsd.pid - uucp
upsmon.pid - root
upslog.pid - root
usbhid-ups-ups - uucp
usbhid-ups-ups.pid - uucp
so the files are created when the nut script is run during boot, but give the following errors
Network UPS Tools upsd
fopen /var/db/nut/upsd.pid No such file or directory
Network UPS Tools upsmon
fopen /var/db/nut/upsmon.pid No such file or directory
Revan
I have the same problem here:
A quick and dirty workaround might be to just copy it back with a cron script that tests if it is still there.
