mablo
- Jan 19, 2012
Hi All
I have searched through the forums and have found a few bits of info but still can't get this working.
I have an APC Back-UPS CS 650 UPS running on FreeNAS-8.0.3-RELEASE-x64 (9395), I have already upgraded from 8.0.2 for the latest NUT install but still no luck :(
I have tried different USB ports and changing the port in the GUI but nothing.
Running on the default config of the files have just set Port to /dev/ugen0.2 (dmesg = ugen0.2: <American Power Conversion> at usbus0) and the Driver as usbhid-ups
When I start the service I get the following:
freenas[1952]: Executing: /usr/sbin/service ix-ups quietstart
freenas[1952]: Executing: /usr/sbin/service nut restart
freenas: Stopping nut.
upsd[5922]: mainloop: Interrupted system call
freenas: Can't open /var/db/nut/usbhid-ups-ugen0.2.pid: No such file or directory
freenas: Network UPS Tools - UPS driver controller 2.6.2
root: Unknown USB device: vendor 0x051d product 0x0002 bus uhub0
freenas: Using subdriver: APC HID 0.95
freenas: Network UPS Tools - Generic HID driver 0.35 (2.6.2)
freenas: USB communication driver 0.31
freenas: libusb_get_report: Unknown error
freenas: Can't initialize data from HID UPS
freenas: Driver failed to start (exit status=1)
root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
freenas: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
freenas[1952]: Executing: /usr/sbin/service nut_upsmon restart
freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
freenas: Starting nut_upsmon.
freenas: UPS: ups (master) (power value 1)
freenas[1952]: Executing: /usr/sbin/service nut_upslog restart
upsmon[6297]: UPS [ups]: connect failed: Connection failure: Connection refused
upsmon[6297]: Communications with UPS ups lost
freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
freenas: Starting nut_upslog.
freenas: Warning: initial connect failed: Connection failure: Connection refused
freenas[1952]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
upsmon[6297]: UPS ups is unavailable
Has anyone had any luck getting the UPS to talk to FreeNAS?
Any help or pointers would be great
Cheers
Cheers
