I'm trying to connect FreeNAS-8.0.4-BETA2 with APC Back-UPS Pro.
It is connected to serial port using apcsmart driver.
When trying to start UPS service i get following messages:
FreeNAS 0.7 communicate with this UPS without problems.
I've found this ticket: http://support.freenas.org/ticket/641 - it seems that this issue should be fixed now?
Feb 18 20:08:31 freenas freenas[1930]: Executing: /usr/sbin/service ix-ups quietstart Feb 18 20:08:32 freenas freenas[1930]: Executing: /usr/sbin/service nut restart Feb 18 20:08:32 freenas freenas: nut not running? (check /var/db/nut/upsd.pid). Feb 18 20:08:32 freenas freenas: Can't uu_lock cuau0: creat error: Permission denied Feb 18 20:08:32 freenas freenas: Network UPS Tools - APC Smart protocol driver 3.0 (2.6.2) Feb 18 20:08:32 freenas freenas: APC command table version 3.0 Feb 18 20:08:32 freenas freenas: Driver failed to start (exit status=1) Feb 18 20:08:32 freenas freenas: Network UPS Tools - UPS driver controller 2.6.2 Feb 18 20:08:32 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Feb 18 20:08:32 freenas freenas: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Feb 18 20:08:32 freenas freenas[1930]: Executing: /usr/sbin/service nut_upsmon restart Feb 18 20:08:32 freenas freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Feb 18 20:08:32 freenas freenas: Starting nut_upsmon. Feb 18 20:08:32 freenas freenas: UPS: ups (master) (power value 1) Feb 18 20:08:32 freenas freenas[1930]: Executing: /usr/sbin/service nut_upslog restart Feb 18 20:08:32 freenas upsmon[3377]: UPS [ups]: connect failed: Connection failure: Connection refused Feb 18 20:08:32 freenas upsmon[3377]: Communications with UPS ups lost Feb 18 20:08:32 freenas freenas: nut_upslog not running? (check /var/db/nut/upslog.pid). Feb 18 20:08:32 freenas freenas: Starting nut_upslog. Feb 18 20:08:32 freenas freenas: Warning: initial connect failed: Connection failure: Connection refused Feb 18 20:08:33 freenas freenas[1930]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd Feb 18 20:08:37 freenas upsmon[3377]: UPS [ups]: connect failed: Connection failure: Connection refused Feb 18 20:08:37 freenas upsmon[3377]: UPS ups is unavailable Feb 18 20:08:42 freenas upsmon[3377]: UPS [ups]: connect failed: Connection failure: Connection refused Feb 18 20:09:12 freenas last message repeated 6 times
