I am fully aware that I screwed up and I deserve to get textually abused for it. :(
That said... HELP!
I upgraded from 9.2.8.1 to 9.3 and then to 11.1U5. <forums> said this was a safe path. I did save my config before hand. I didn't check things over that much at the 9.3 stage and didn't resave the config at that point. When I arrived at 11.1, I had no plugins, no jails, no users and no shares. the data appeared ok. I did not realize all of this was missing at the time and was focused on the plugins, two of which I wanted to keep: nextcloud and plex. I was a bit freaked out because I was under the impression they would be brought along without a problem. I thought if I installed them, they might pickup the old configuration.- since this altered the disk, I this it's the cause of most of my problem.
I was a bit timid about uploading the configuration - I was not confidant I could do this from a much older version without harm. I'm more comfortable and knowledgeable now.
My user accounts, shares, jails and some old/unused plugings are back, but when I try to start plex or nextcloud, I have errors. I am unsure where to go from here. is it still possible for me to get the old plugin configuration back? I'm not so worried about plex, but nextcloud is important to me.
Looking in the volumes, I can see a 'jails' with my old jails in there, and a 'jails_2' with what I assume is the new plugins I installed.
Thanks in advance, and please try to be gentile. :(
- Dan
That said... HELP!
- the short version is that I installed plex & nextcloud again before applying the old configuration. I think that's the cause of them not starting.
- Dan
