I am a relative newbie, but have a bit of a grasp on TrueNAS. My problem is that one of my pools is showing as unhealthy, and all the drives in that pool are showing the same numbers of CHKSUM errors. If the server is rebooted, the error count drops to 12 (or maybe less), but one can see it climbing steadily, and each of the four drives shows the same number of errors. I have done scrubs, but nothing seems to help. smartctl for each drive shows no errors, but zpool -v status shows the below : (this is after the server has been up for 2hrs 47mins, so shows the steady climb of the CHKSUM errors on NAS_Volume
Hope someone might have an idea why this is occurring, or what else I can do to rectify or identify faults. All of the drives are SATA using the mobo onboard connectors, I have change all of the SATA cables, changed the PSU, now I am wondering if the mobo is damaged.
zpool status -v
codeblock zpool status -v pool: Jails_Vol state: ONLINE status: Some supported and requested features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub canceled on Thu Aug 31 13:27:57 2023 remove: Removal of vdev 1 copied 5.35M in 0h0m, completed on Thu Feb 16 12:13:48 2023 6.12K memory used for removed device mappings config: NAME STATE READ WRITE CKSUM Jails_Vol ONLINE 0 0 0 gptid/58c3104d-b43b-11ed-a2b1-38d547270c9d ONLINE 0 0 0 errors: No known data errors pool: NAS_Volume state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub in progress since Mon Sep 4 13:46:09 2023 1.72T scanned at 520M/s, 1.26T issued at 383M/s, 4.00T total 0B repaired, 31.62% done, 02:04:45 to go config: NAME STATE READ WRITE CKSUM NAS_Volume ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/80be4e45-a941-11e6-8723-38d547270c9d ONLINE 0 0 7.50K gptid/8176984f-a941-11e6-8723-38d547270c9d ONLINE 0 0 7.50K gptid/8222f585-a941-11e6-8723-38d547270c9d ONLINE 0 0 7.50K gptid/82d5dcfc-a941-11e6-8723-38d547270c9d ONLINE 0 0 7.50K errors: Permanent errors have been detected in the following files: <0xffffffffffffffff>:<0x1052> pool: boot-pool state: ONLINE config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
