VulcanRidr
 - Jan 5, 2015
Hope everyone had a great Christmas,
My TrueNAS box consists of 6 4TB drives. However, I found a good deal on 10TB HGST drives. I got two for my birthday, and replaced the first two drives. Well, my gift from my family was the 4 remaining 10TB drives with which to complete the upgrade. The pool is RAID-Z2
So drives 0 and 1 had been upgraded earlierin the year, and I, one each in turn, powered down the system, replaced the 4TB with a 10TB drive, powered up, and under
Now in the
So a couple of questions. There are two /dev/gptid devices, one showing UNAVAIL and one showing REMOVED. I am taking an educated guess that the REMOVED one is the 10TB that had an interrupted resilver, and the UNAVAIL is the 10TB one. How can I get this drive back into the pool? Detach seems to be a permanent solution, and Remove seems almost as permanent. Since the resilver completed, is there a way to get it to recognize the 6th drive?
Thanks,
--vr
Storage -> Pools -> Status did a Replace, then let the system resilver. When it completed, I moved on to the next drive. All was going on swimmingly, until the final drive. It gave me some (72) write errors, then the system rebooted. When it came up, the write errors had cleared, and it completed the resilver. However, it still shows the pool as DEGRADED, and zpool status on the data pool shows:Code:
root@luna[~]# zpool status NX80101
  pool: NX80101
 state: DEGRADED
  scan: resilvered 9.57G in 13:24:31 with 0 errors on Thu Dec 28 14:26:02 2023
        NAME                                                  STATE     READ WRITE CKSUM
        NX80101                                               DEGRADED     0     0     0
          raidz2-0                                            DEGRADED     0     0     0
            gptid/f875bb06-1488-11ee-abb2-0cc47a7e13b8.eli    ONLINE       0     0     0
            gptid/39f81b1f-2f31-11ee-b805-0cc47a7e13b8.eli    ONLINE       0     0     0
            gptid/8d46a0c4-a428-11ee-9f7c-0cc47a7e13b8.eli    ONLINE       0     0     0
            gptid/64879c61-a385-11ee-8760-0cc47a7e13b8.eli    ONLINE       0     0     0
            gptid/56304af5-a4ca-11ee-83e7-0cc47a7e13b8.eli    ONLINE       0     0     0
            replacing-5                                       UNAVAIL      0     0     0  insufficient replicas
              13809399577626154655                            UNAVAIL      0     0     0  was /dev/gptid/99538994-abb8-11eb-ba64-0cc47a7e13b8.eli
              gptid/87677b78-a546-11ee-b4dc-0cc47a7e13b8.eli  REMOVED      0     0     0
errors: No known data errorsNow in the
Pool Status display in the GUI (https://imgur.com/BWelmtm), it gives me a number of options when I click on the vertical dots on either of the /dev/gptid, it gives me the options to Edit, Offline, Replace, Remove, or Detach. I tried clicking on Replace, but there are no Member Disks to choose.So a couple of questions. There are two /dev/gptid devices, one showing UNAVAIL and one showing REMOVED. I am taking an educated guess that the REMOVED one is the 10TB that had an interrupted resilver, and the UNAVAIL is the 10TB one. How can I get this drive back into the pool? Detach seems to be a permanent solution, and Remove seems almost as permanent. Since the resilver completed, is there a way to get it to recognize the 6th drive?
Thanks,
--vr
