Bad drive or cable?: "(da9:mps1:0:2:0): SCSI sense: ABORTED COMMAND asc:47,3 (Information unit iuCRC
esamett
Security output email today:
freenas.domain kernel log messages:
>   (da9:mps1:0:2:0): READ(10). CDB: 28 00 1d 98 2c e0 00 00 20 00 length 16384 SMID 875 terminated ioc 804b scsi 0 state 0 xfer 0
> (da9:mps1:0:2:0): READ(10). CDB: 28 00 1d 98 2c c0 00 00 20 00
> (da9:mps1:0:2:0): CAM status: SCSI Status Error
> (da9:mps1:0:2:0): SCSI status: Check Condition
> (da9:mps1:0:2:0): SCSI sense: ABORTED COMMAND asc:47,3 (Information unit iuCRC error detected)
> (da9:mps1:0:2:0): Retrying command (per sense data)
-- End of security output --
Smart error email message:
Subject: SMART error (ErrorCount) detected on host: freenas
This message was generated by the smartd daemon running on:
host name:  freenas
DNS domain: domain
The following warning/error was logged by the smartd daemon:
Device: /dev/da9 [SAT], ATA error count increased from 0 to 1
Device info:
HGST HDN724040ALE640, S/N:PK2381PBHATTLR, WWN:5-000cca-23dd30049, FW:MJAOA5E0, 4.00 TB
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
No additional messages about this problem will be sent.
smartctl -a /dev/da9 output:
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:  HGST HDN724040ALE640
Serial Number:  PK2381PBHATTLR
LU WWN Device Id: 5 000cca 23dd30049
Firmware Version: MJAOA5E0
User Capacity:  4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  7200 rpm
Device is:  Not in smartctl database [for details use: -P showall]
ATA Version is:  ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Fri Oct 31 18:14:17 2014 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
  was completed without error.
Self-test execution status:  (  0) The previous self-test routine completed
  been run.
data collection:  (  24) seconds.
capabilities:  (0x5b) SMART execute Offline immediate.
  Auto Offline data collection on/off supp
ort.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  1) minutes.
Extended self-test routine
recommended polling time:  ( 556) minutes.
SCT capabilities:  (0x003d) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x000b  100  100  016  Pre-fail  Always  -
  0
  2 Throughput_Performance  0x0005  136  136  054  Pre-fail  Offline  -
  80
  3 Spin_Up_Time  0x0007  131  131  024  Pre-fail  Always  -
  605 (Average 576)
  4 Start_Stop_Count  0x0012  100  100  000  Old_age  Always  -
  26
  5 Reallocated_Sector_Ct  0x0033  100  100  005  Pre-fail  Always  -
  0
  7 Seek_Error_Rate  0x000b  100  100  067  Pre-fail  Always  -
  0
  8 Seek_Time_Performance  0x0005  124  124  020  Pre-fail  Offline  -
  33
  9 Power_On_Hours  0x0012  100  100  000  Old_age  Always  -
  1981
10 Spin_Retry_Count  0x0013  100  100  060  Pre-fail  Always  -
  0
12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -
  26
192 Power-Off_Retract_Count 0x0032  100  100  000  Old_age  Always  -
  97
193 Load_Cycle_Count  0x0012  100  100  000  Old_age  Always  -
  97
194 Temperature_Celsius  0x0002  171  171  000  Old_age  Always  -
  35 (Min/Max 24/50)
196 Reallocated_Event_Count 0x0032  100  100  000  Old_age  Always  -
  0
197 Current_Pending_Sector  0x0022  100  100  000  Old_age  Always  -
  0
198 Offline_Uncorrectable  0x0008  100  100  000  Old_age  Offline  -
  0
199 UDMA_CRC_Error_Count  0x000a  200  200  000  Old_age  Always  -
SMART Error Log Version: 1
ATA Error Count: 2
  CR = Command Register [HEX]
  FR = Features Register [HEX]
  ER = Error register [HEX]
  ST = Status register [HEX]
Error 2 occurred at disk power-on lifetime: 1974 hours (82 days + 6 hours)
  When the command that caused the error occurred, the device was active or idle
ER ST SC SN CL CH DH
  84 51 01 27 e1 6d 00  Error: ICRC, ABRT at LBA = 0x006de127 = 7201063
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  60 20 00 08 e1 6d 40 00  1d+03:06:22.004  READ FPDMA QUEUED
  60 20 00 e8 e0 6d 40 00  1d+03:06:22.004  READ FPDMA QUEUED
  60 20 00 c8 e0 6d 40 00  1d+03:06:22.004  READ FPDMA QUEUED
  60 20 00 a8 e0 6d 40 00  1d+03:06:22.002  READ FPDMA QUEUED
  60 20 00 88 e0 6d 40 00  1d+03:06:22.001  READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 1965 hours (81 days + 21 hours)
  84 51 01 df 2c 98 0d  Error: ICRC, ABRT at LBA = 0x0d982cdf = 228076767
  60 20 18 e0 2c 98 40 00  18:14:52.246  READ FPDMA QUEUED
  60 20 10 c0 2c 98 40 00  18:14:52.246  READ FPDMA QUEUED
  60 20 08 a0 2c 98 40 00  18:14:52.246  READ FPDMA QUEUED
  60 20 00 80 2c 98 40 00  18:14:52.246  READ FPDMA QUEUED
  60 08 00 48 e8 58 40 00  18:14:52.246  READ FPDMA QUEUED
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA
_of_first_error
# 1  Short offline  Completed without error  00%  1057  -
# 2  Short offline  Completed without error  00%  1015  -
# 3  Short offline  Completed without error  00%  967  -
# 4  Short offline  Completed without error  00%  919  -
# 5  Short offline  Completed without error  00%  871  -
# 6  Short offline  Completed without error  00%  823  -
# 7  Short offline  Completed without error  00%  775  -
# 8  Extended offline  Completed without error  00%  762  -
# 9  Short offline  Completed without error  00%  727  -
#10  Short offline  Completed without error  00%  679  -
#11  Short offline  Completed without error  00%  633  -
#12  Short offline  Completed without error  00%  585  -
#13  Short offline  Completed without error  00%  561  -
#14  Short offline  Completed without error  00%  513  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Long smart test started:
[root@freenas ~]# smartctl -t long /dev/da9
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-li
ne mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line
mode" successful.
Testing has begun.
Please wait 556 minutes for test to complete.
Test will complete after Sat Nov 1 03:41:18 2014
Use smartctl -X to abort test.
[root@freenas ~]#
Question: Bad drive, cable, Halloween gremlins? I searched the error on this forum and the one result I saw diagnosed a bad backplane after multiple disks errors noted. I have 8087 to SATA fan cables in use. This is the only error that has come up recently after I changed a bad cable and wiped out the old errors from an old 2TB drive. I briefly had temps to around 40'C while heating my room while PRIME95 testing my desktop. Otherwise no FreeNAS issues at all for about two months.
Thanks...as always.
Could be the cable, I see two UDMA CRC errors.
Basically the communication between your SAS/SATA controller and hard drive had a problem. So anything that could impact that communication is suspect. The data cable is the easiest, so that's the first thing we recommend people replace. It's cheap and easy so why not? ;)
esamett
These guys are really fragile!! Any recommendation for a "sturdy" one?
More messages:
Security output:
> (da9:mps1:0:2:0): READ(10). CDB: 28 00 20 6d e1 08 00 00 20 00
>   (da9:mps1:0:2:0): WRITE(10). CDB: 2a 00 38 24 5e 48 00 00 18 00 length 12288 SMID 654 terminated ioc 804b scsi 0 state c xfer 0
> (da9:mps1:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
> (da9:mps1:0:2:0): READ(16). CDB: 88 00 00 00 00 01 0f b3 31 b0 00 00 00 20 00 00
smartctl -a /dev/da9 output after overnight long test:
Local Time is:  Sat Nov  1 08:11:05 2014 PDT
Shell
Self-test execution status:  (  38) The self-test routine was interrupted
  by the host with a hard or soft reset.
ort.
  command.
  power-saving mode.
FAILED RAW_VALUE
  0
  80
  605 (Average 576)
  26
  0
  0
Shell
  33
  1995
  0
  26
  98
  98
194 Temperature_Celsius  0x0002  166  166  000  Old_age  Always  -
  36 (Min/Max 24/50)
  0
  0
  0
Shell
ATA Error Count: 2
Shell
_of_first_error
# 1  Extended offline  Interrupted (host reset)  60%  1985  -
# 2  Short offline  Completed without error  00%  1057  -
# 3  Short offline  Completed without error  00%  1015  -
# 4  Short offline  Completed without error  00%  967  -
# 5  Short offline  Completed without error  00%  919  -
# 6  Short offline  Completed without error  00%  871  -
# 7  Short offline  Completed without error  00%  823  -
# 8  Short offline  Completed without error  00%  775  -
# 9  Extended offline  Completed without error  00%  762  -
#10  Short offline  Completed without error  00%  727  -
#11  Short offline  Completed without error  00%  679  -
#12  Short offline  Completed without error  00%  633  -
#13  Short offline  Completed without error  00%  585  -
#14  Short offline  Completed without error  00%  561  -
#15  Short offline  Completed without error  00%  513  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
[root@freenas ~]#
Please let me know any further input. I will update as appropriate.
Thanks,
e
Well, keeping cables as short as possible (and always below one meter) helps. Otherwise, it's just a matter of luck.
esamett
Dagnabbit...
Same cable location that I replaced before. I hope its not the HBA. I will swap spare cable and reroute.
Looking forward, can you suggest an affordable case (used is fine) that fits 22 drives. I have two nice ATX PSU and lots of quiet 12/14 cm fans to swap out the server "jet engines.":D
Aitor
Good Afternoon:
I have freenas 9.2.1.8 version, and same error. This was not happened with version 8.3.
I have upgrade my lsi sas adapter firmware to the last version and freenas mpslsi driver also, but still has problems.
Thanks.
Well, if you upgraded to the latest version you upgraded too far. The firmware version should match the driver version. This has been discussed to death in the forums. Please search the forums if you are interested in more information.
Aitor
Yeah, I read it before than I upgrade the firmware but I have upgrade the freenas driver, and i still have the problem.
If you upgraded the FreeNAS driver you are now in the realm of totally unsupported and on your own. We don't support custom builds of FreeNAS with custom drivers. Sorry. The p16 is used because it's the most stable and most tested version out for FreeBSD.
RobertNAS
Hi, I'm a new face here, and a n00b when it comes to FreeBSD/FreeNAS. I do have a science and engineering BS, and I've been working as a software developer and systems engineer for almost 10 years. So I'm liking the challenge of learning FreeNAS. I've necro'd this thread to pile on my recent experience with LSI drivers and to acknowledge the point made by cyberjock.
Downgrading firmware on a new LSI|9201-16E naturally goes against everything I've been taught in the Windows Server domain. So, I ended up "experimenting" with the p20 firmware and the p20 driver in FreeNAS 9.3. This didn't work out so good. It seems to have caused a few thousand UDMA_CRC_Error_Count ticks on every drive, and even caused the zpool to fault on two different drives, though not at the same time. This all happened in the first couple days of building and testing the system.
One of the many signs of trouble were a ton of SCSI status errors in the logs. Here's an example of the log spam:
(da1:mpslsi0:0:1:0): CAM status: SCSI Status Error
(da1:mpslsi0:0:1:0): SCSI status: Check Condition
(da1:mpslsi0:0:1:0): SCSI sense: ABORTED COMMAND asc:47,3 (Information unit iuCRC error detected)
(da1:mpslsi0:0:1:0): Retrying command (per sense data)
(da1:mpslsi0:0:1:0): READ(10). CDB: 28 00 08 ac d3 e8 00 00 78 00 length 61440 SMID 919 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mpslsi0:0:1:0): READ(10). CDB: 28 00 08 ac e0 40 00 00 20 00
Bottom line, if you've come across this thread with the same issues, get the p16 firmware and use the included driver. Google whatever it takes to figure out how to flash a downgrade. What finally worked for me was simply creating a DOS boot disk with Rufio on a USB drive and then downloading the p16 firmware package for MSDOS & Windows from the LSI archives.
From the DOS prompt, it was two simple commands:
sas2flsh.exe -o -e 6
sas2flsh.exe -o -f 9201-16e.bin -b mptsas2.rom
Other attempts to downgrade the firmware from various FreeBSD/Linux/UEFI shells with their respective versions of the sas2flash tool failed for one reason or another. "Go DOS, or go home," I guess.
isamudysan
i'm currently getting the same errors as stated on here. i'll do scrub and smart test. if that all checks out then i'll downgrade. i have a supermicro x9scm mobo, and after researching prior to cross flashing my m1015 card, the flash via uefi was fine. after cross flashing with p20 fw, had a problem post install as i got a alert from my nas about firmware not matching a driver. after researching it, i came across this: https://bugs.freenas.org/issues/6678. i followed phoenix one's post in creating a tunable, and the alert did go away. since then never had any issues till recently after a few updates that i started seeing these errors. so, i guess i'll need to delete the tunable, the mpslsi.ko, downgrade the firmware and see what happens, right?
i hope that downgrading via uefi will be the same, hopefully. i'll keep robertnas' last statement, "Other attempts to downgrade the firmware from various FreeBSD/Linux/UEFI shells with their respective versions of the sas2flash tool failed for one reason or another. 'Go DOS, or go home,' I guess," in mind.
EDIT 1 02/26/2015
i downgraded from p20 drivers to p16 -- had to google the p16 drivers, and installers (just in case). took awhile to find the much needed files since i think the files got archived by avago (fka lsi). in any case, the downgrade so far has worked and i have not seen the aforementioned error since then. i will, however, keep monitoring if it'll pop up. and, yes, i did disable the p20 drivers via tunable. also, i did scrub and do a smart test and everything prior to the downgrade was fine -- it's a new build after all...only been like 6 days old lol. hope this helps. a great thanks to the freenas community :D
EDIT 2:
i also note that with the p20 drivers my cpu and memory load was very high when no one was accessing it. with the downgrade to p16 everything sort of leveled off to normalcy. thank you freenas community :D
esamett
it was a bad cable for me. The HBA works great with new cable and p16 firmware.
