LIGISTX
- Apr 12, 2015
I’m sure his has been covered 17 times by now, but I did do some googling and searching and didn’t quite find what I wanted. Granted I’m on a phone, so that’s a little limiting. But seeing as I’ll be setting up my freenas box soon, just in time for my crashplan home plan to go away (thanks guys... 3 TB worth of data I have to re-upload across a few different PC’s) I will want to try and get my backblaze account working with my soon to be freenas setup.
I currently have a few of the normal PC backup accounts, or I guess I should say multiple PC’s registered under the single normal home account.
Does freenas support this, or would I have to use B2? I’m really not trying to backup the world with this which I figure is why backblaze doesn’t allow network storage to be backed up, but because of this limitation I am unsure of what freenas does support.
Is there a built in plugin for this, would I want to run some headless Linux VM under freenas and do it somehow this way? Should I look at another strategy all together? I don’t want to throw a task that will greatly increase my systems overhead, but I will have an i3 6100 and 20 GB of ram for a relatively simple single person NAS, it should have plenty of headroom to spare.
The only data I will want to backup is ~2-3TB worth.
Any advice would be awesome.
