pixelwave
- Jan 26, 2022
Not sure if that ensures "full ECC" functionality but if I query:I thought that I read somewhere that the non-X Ryzen cpu's do not offer any ECC capability, but apparently your TrueNAS does show up with ECC.
Does anyone here know how to find error correction events in the logs of Truenas Scale?
dmidecode -t memory
In my proxmox shell I get "multi-bit ECC":
Handle 0x0018, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: Multi-bit ECC
Maximum Capacity: 128 GB
Error Information Handle: 0x0017
Number Of Devices: 4And for single slots shows also unregistered:
Handle 0x0020, DMI type 17, 92 bytes
Memory Device
Array Handle: 0x0018
Error Information Handle: 0x001F
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL A
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 3200 MT/s
Manufacturer: Kingston
Serial Number: CBF950C5
Asset Tag: Not Specified
Part Number: 9965745-039.A00G
Rank: 2
Configured Memory Speed: 2666 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Unknown
Module Manufacturer ID: Bank 2, Hex 0x98
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 32 GB
Cache Size: None
Logical Size: None
