I've been running TrueNAS-SCALE-21.04 for a bit now and core before that, for a month or so. I plan on sticking with SCALE for the foreseeable future. I hope. ;-)
This will be mostly used for typical NAS storage of home dirs, photos, home videos and Plex serving family and friends. Max users would be 8-9 with 5-6 transcodes at a time (NOT from 4k at this time) ;-)
Anyway... I have the following and will need more SATA ports pretty soon.
ASRock X5700M PRO4
AMD Ryzen 7 3700X
64GB DDR4 ECC (4x 16GB sticks)
Nvidia Quadro P600 (for plex transcoding hopefully in the not to distant future)
Intel X540-T2 10Gb NIC
I have a 1TB NVMe for download and transcoding space in one of the m.2 slots. (not protected because I don't care if I lose it)
120GB SSD in an external USB 3.1 gen2 case for boot drive (unprotected but will be saving config off to another system)
2x 1TB SSDs mirrored for appdata (VMs and applications)
6x 4TB spinners for data
With current disk prices I just can't justify installing larger HDs and expanding the datapool AND I'm out of onboard SATA ports. I have the NIC in one of the PCIe 4.0 x16 slots and the P600 in the other. This leaves me with one PCIe 4.0 x1 slot free and the other m.2 slot free. I ran across this and wondered if it might solve my issue of needing more SATA ports. m.2 riser Would this work for for say an LSI 9207 (or similar) to give me more SATA ports? Is it recommended to do this? Is there a better solution?
I could/would drop the 10Gb NIC but my primary NAS currently is a QNAP with 10Gb and I do move a lot of data at times. Once in more familiar with SCALE, and it's out of ALPHA, I'd like to make SCALE my primary and just use the QNAP for backups.
Thoughts, suggestions?
TIA
ASRock X5700M PRO4
AMD Ryzen 7 3700X
TIA
