After the start always IP 0.0.0.0
New-User
I always get an IP address of 0.0.0.0 when I start up. What could be the reason for this?
In the BIOS I have only enabled everything that I can run WOL, which also does not work.
When the computer is off and I try to run WOL from Windows with a program, the motherboard Gigabyte GA-F2A78M-HD2 is recognized under the IP or MAC address.
I can go after starting TrueNAS in the small menu to reconfigure the network, all is useless, it always comes back 0.0.0.0.
I have already changed cables, changed connections (router or switch), nothing helps.
How do I get back to the known IP address? In the FritzBox is set that the computer should always get the same IP, which had always worked until now.
Thanks :smile:
Don't use DHCP, set a static IP on that interface.
New-User
I reset the BIOS, now it was running normally again.
I have to test further...
With the static IP address I will also set. Thanks for the hint.
