Hello guys,
I have little hope left, so let me tell you what I did and maybe you can tell me whether I screwed up.
Was running a FreeNAS-11.3-RELEASE w/o issues for long. Now my 1st dataset was running full, so I:
It says "[EFAULT] Pool could not be imported: 3 devices failed to decrypt. " I reconnected the disconnected 4th drive for the original pool, and this one seems fine.
What could have gone wrong and what can I try to fix it?
Best Regards,
Daniel
PS:
- added 3 new drives
- disconnected 1 of the 4 of the original pool due to number of connector on the board.
- Started freenas and created a 2nd pool with the 3 new drives
- Did do the snapshot, zfs send | zfs receive to the new pool...
- unfortunately it was interrupted (closed the terminal *arg*).so I had to delete the new pool. That's what I did in the UI, and I did only delete the _new_ pool.
- Restarted my Freenas system, and wanted to unlock the original pool, then this error comes since.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.7/concurrent/futures/process.py", line 239, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 95, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 51, in _run
return await self._call(name, serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 43, in _call
return methodobj(*params)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 964, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 382, in import_pool
zfs.import_pool(found, found.name, options, any_host=any_host)
File "libzfs.pyx", line 369, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 870, in libzfs.ZFS.import_pool
libzfs.ZFSException: no such pool or dataset
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/pool.py", line 1656, in unlock
'cachefile': ZPOOL_CACHE_FILE,
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1127, in call
app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1074, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1094, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1029, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1003, in run_in_executor
libzfs.ZFSException: ('no such pool or dataset',)
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
await self.future
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 386, in __run_body
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/pool.py", line 1668, in unlock
raise CallError(msg)
middlewared.service_exception.CallError: [EFAULT] Pool could not be imported: 3 devices failed to decrypt.
Best Regards,
Daniel
PS:
root@datengrab:~ # zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:05:59 with 0 errors on Mon Feb 22 03:50:59 2021
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
errors: No known data errors
