You meant 93F right? Not 93Celsius (that's almost 200 degrees F)
First off, I would go back to your previous boot environment and check to see if the problem
resolves itself. if it does, it's going to be either a BSD compatibility issue with the mobo chipset,
or a bios update. From time to time BSD drops support for hardware and your board/chip/bios
may be affected.
I mean 93C assuming sysctl reports it correctly?
I just changed one thing that I can't imagine was the root cause but who knows — I rebuilt a binary for the RealTek driver against the FreeBSD 11 kernel sources in a VM. If I don't use the RealTek-provided driver the network stack freezes after some condition related to utilization and requires a reboot, and after upgrading to FreeNAS 11 I knew I'd be needing to rebuild it.
After I built it, copied it over, loaded it successfully and the cpu throttle_log had either hit 1 or stayed at 0 across all cores, the problem resolved.
I suppose it's possible that attempting to load the old module unsuccessfully could have put the kernel into a state where it was absurdly busy or something that resolved itself after loading a module that worked?
Or could be completely unrelated.
I'll include the relevant/interesting values from sysctl in-line:
hw.acpi.thermal.tz1.temperature: 29.9C
hw.acpi.thermal.tz0.temperature: 27.9C
dev.coretemp.7.%parent: cpu7
dev.coretemp.7.%pnpinfo:
dev.coretemp.7.%location:
dev.coretemp.7.%driver: coretemp
dev.coretemp.7.%desc: CPU On-Die Thermal Sensors
dev.coretemp.6.%parent: cpu6
dev.coretemp.6.%pnpinfo:
dev.coretemp.6.%location:
dev.coretemp.6.%driver: coretemp
dev.coretemp.6.%desc: CPU On-Die Thermal Sensors
dev.coretemp.5.%parent: cpu5
dev.coretemp.5.%pnpinfo:
dev.coretemp.5.%location:
dev.coretemp.5.%driver: coretemp
dev.coretemp.5.%desc: CPU On-Die Thermal Sensors
dev.coretemp.4.%parent: cpu4
dev.coretemp.4.%pnpinfo:
dev.coretemp.4.%location:
dev.coretemp.4.%driver: coretemp
dev.coretemp.4.%desc: CPU On-Die Thermal Sensors
dev.coretemp.3.%parent: cpu3
dev.coretemp.3.%pnpinfo:
dev.coretemp.3.%location:
dev.coretemp.3.%driver: coretemp
dev.coretemp.3.%desc: CPU On-Die Thermal Sensors
dev.coretemp.2.%parent: cpu2
dev.coretemp.2.%pnpinfo:
dev.coretemp.2.%location:
dev.coretemp.2.%driver: coretemp
dev.coretemp.2.%desc: CPU On-Die Thermal Sensors
dev.coretemp.1.%parent: cpu1
dev.coretemp.1.%pnpinfo:
dev.coretemp.1.%location:
dev.coretemp.1.%driver: coretemp
dev.coretemp.1.%desc: CPU On-Die Thermal Sensors
dev.coretemp.0.%parent: cpu0
dev.coretemp.0.%pnpinfo:
dev.coretemp.0.%location:
dev.coretemp.0.%driver: coretemp
dev.coretemp.0.%desc: CPU On-Die Thermal Sensors
dev.coretemp.%parent:
dev.cpu.7.temperature: 62.0C
dev.cpu.7.coretemp.throttle_log: 0
dev.cpu.7.coretemp.tjmax: 98.0C
dev.cpu.7.coretemp.resolution: 1
dev.cpu.7.coretemp.delta: 36
dev.cpu.6.temperature: 62.0C
dev.cpu.6.coretemp.throttle_log: 1
dev.cpu.6.coretemp.tjmax: 98.0C
dev.cpu.6.coretemp.resolution: 1
dev.cpu.6.coretemp.delta: 36
dev.cpu.5.temperature: 58.0C
dev.cpu.5.coretemp.throttle_log: 0
dev.cpu.5.coretemp.tjmax: 98.0C
dev.cpu.5.coretemp.resolution: 1
dev.cpu.5.coretemp.delta: 40
dev.cpu.4.temperature: 58.0C
dev.cpu.4.coretemp.throttle_log: 1
dev.cpu.4.coretemp.tjmax: 98.0C
dev.cpu.4.coretemp.resolution: 1
dev.cpu.4.coretemp.delta: 40
dev.cpu.3.temperature: 59.0C
dev.cpu.3.coretemp.throttle_log: 1
dev.cpu.3.coretemp.tjmax: 98.0C
dev.cpu.3.coretemp.resolution: 1
dev.cpu.3.coretemp.delta: 39
dev.cpu.2.temperature: 59.0C
dev.cpu.2.coretemp.throttle_log: 1
dev.cpu.2.coretemp.tjmax: 98.0C
dev.cpu.2.coretemp.resolution: 1
dev.cpu.2.coretemp.delta: 39
dev.cpu.1.temperature: 56.0C
dev.cpu.1.coretemp.throttle_log: 0
dev.cpu.1.coretemp.tjmax: 98.0C
dev.cpu.1.coretemp.resolution: 1
dev.cpu.1.coretemp.delta: 42
dev.cpu.0.temperature: 56.0C
dev.cpu.0.coretemp.throttle_log: 1
dev.cpu.0.coretemp.tjmax: 98.0C
dev.cpu.0.coretemp.resolution: 1
dev.cpu.0.coretemp.delta: 42
It's holding in the 50-60Cs now and as long as that continues to happen I have no problem. Would really like to know the root cause though obviously so that it doesn't melt itself while I'm out of town.
