SOLVED AFP Home Share naming scheme
mikemand
I have tried several different searches (both here on the forums and on Google) about changing how the Home Share is named. Right now, my home shares are all
<username>'s home
. Is there some way I can change them to be just <username>?
I have a FreeNAS Mini running FreeNAS 11.2-BETA3. My Dataset is setup like so:
And my AFP Share:
mikemand
Hi @m0nkey_,
Thank you for the information! I didn't know that, and the docs don't say it (at least as far as I could find).
Do you know if I am able to change the format of my Dataset without data loss? It's currently set to Mac, but I should change it to Unix for better SMB compatibility, correct?
Either way, I will change the format of all of my shares to SMB, instead of AFP. Thank you!
