Advice on faulty drive/resilvering
David Buchanan
Hi All,
I'm looking for some advice to resolve my issue with what I believe is a faulty drive (maybe two) as I'm still learning Freenas.
A little info about my system:
CPU: Intel Xeon W3530
MEMORY: 24GB Samsung ECC Ram
HDD: 5 x 2TB WD in RAIDZ1
MOBO: Ausu P6T Deluxe
RUNNING: FreeNAS-9.10-STABLE-201606270534 (dd17351)
This morning I got an email from my NAS:
The volume ZFS1 (ZFS) state is ONLINE: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state.
Running zpool status -v I get the following:
pool: ZFS1
state: ONLINE
status: One or more devices is currently being resilvered. The pool will
action: Wait for the resilver to complete.
scan: resilver in progress since Wed Aug 17 12:47:49 2016
73.1M scanned out of 6.81T at 18.6K/s, (scan is slow, no estimated time)
6.61M resilvered, 0.00% done
NAME STATE READ WRITE CKSUM
ZFS1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/bbb6c3ef-fd39-11e3-b935-001f29554225 ONLINE 0 0 0 (resilvering)
gptid/bc263c59-fd39-11e3-b935-001f29554225 ONLINE 0 0 0
gptid/bccdac9d-fd39-11e3-b935-001f29554225 ONLINE 0 0 0
gptid/bd5b3a21-fd39-11e3-b935-001f29554225 ONLINE 0 0 0
gptid/be37c79c-fd39-11e3-b935-001f29554225 ONLINE 0 0 0 (resilvering)
ZFS1/Backups:<0x2f>
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h11m with 0 errors on Sun Aug 7 03:56:03 2016
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
As you can see two of my drives are showing resilvering.
Does this mean only one has issuies and another drive is being used to resolve it, or do I have two drives with problems?
Also, the resilver speed is ridiculously slow, 18.6K/s. Again this makes me think there is a faulty drive.
The console on the server shows the following message over and over again:
(ada0:ahcich0:0:0) : CAM status: ATA Status Error
(ada0:ahcich0:0:0) : ATA status: 41 (DRDY ERR), error: 40 (UNC )
(ada0:ahcich0:0:0) : RES: 41 40 c0 40 fb 19 00 00 00 00
(ada0:ahcich0:0:0) : Retrying command
(ada0:ahcich0:0:0) : READ_FPDMA_QUEUED. ACB: 60 08 c0............... massive string of digits.
Am I correct in thinking the drive ada0 is screwed and needs replacing?
Can I offline ada0 and replace it or does the fact I have two drives showing "resilvering" mean I need to take a different course of action (I have a spare drive here ready to go into the system).
I'd appericate any help you can give me. :)
Thanks
David
CraigD
If they are resilvering I would wait and not do a thing until at least one drive is resilvered and then change the SATA data cable on ada0
I would not stress the drives at all no writes at all and only limited reads,, do one thing wrong now and you may be lose your data
If you have a back the decision is easier, buy two new drive test them, replace the faulting drives, the check the data cables destroy the pool a recover from your backup, then look at the drives you pulled
I am confused as to a RAIDz1 vdev being able to resilver two drives at the same time
Have Fun
David Buchanan
OK, so there is differently something wrong with ada0.
smartclt -a /dev/ada0 outputs:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Caviar Green (AF)
Device Model: WDC WD20EARS-00MVWB0
Serial Number: WD-WCAZA1436668
LU WWN Device Id: 5 0014ee 2afb5c646
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Aug 17 15:33:44 2016 AEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (37200) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 359) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 198 198 051 Pre-fail Always - 31775
3 Spin_Up_Time 0x0027 169 167 021 Pre-fail Always - 6516
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 297
5 Reallocated_Sector_Ct 0x0033 153 153 140 Pre-fail Always - 904
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 046 046 000 Old_age Always - 39977
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 296
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 275
193 Load_Cycle_Count 0x0032 051 051 000 Old_age Always - 447815
194 Temperature_Celsius 0x0022 116 089 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 268
197 Current_Pending_Sector 0x0032 001 001 000 Old_age Always - 65504
198 Offline_Uncorrectable 0x0030 200 199 000 Old_age Offline - 185
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 184 179 000 Old_age Offline - 4515
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 90% 25343 3827330289
# 2 Extended offline Completed: read failure 90% 23495 3827330290
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If I'm reading that correctly that's lots of bad sectors on ada0. I've checked all the other drives, including ada4 which is the 2nd drive resilvering and they all have 0 bad sectors being reported by smart.
My issue here is as you say Criag, how can I have two drives resilvering on a RAIDZ1?
With the speed the resilver is progressing at (now 11.8K/s) I don't see how the 6.81TB will ever complete.
I have a complete backup of all the important data on this NAS, so I'm not in any panic about resolving this. This system is also a home NAS, it has very little I/O going onto it. I'm more interested in fixing it for the learning experience.
Thanks,
David.
Robert Trevellyan
Pony Wrangler
Is ada0 one of the drives that's marked as "resilvering"?
Ideally you'd replace that drive immediately based on the smartctl output, but with your current pool status and RAIDZ1, this might be a bad move.
Robert Trevellyan
Pony Wrangler
OK, then the poor performance is not surprising. You're in a tough spot.
Since you have a full backup, it might be worth risking a shutdown, to double-check all drive power and data cables.
If you can get to a zpool status that only shows one drive resilvering, then you can follow the directions in the manual for replacing a failing drive. If not, I would suspect a corrupted pool.
David Buchanan
The zpool is still working, I can access the CIFS shares. It's just very slow. Not surprising given the status of ada0.
I'll check all the cables tonight as you suggest and see how it goes. If that doesn't help I'll either leave it for a while to see if it gets to a status of just one drive resilvering. If not, I may just have to risk trying to replace ada0 even tho ada4 is also in a resilvering state.
I'm still confused as to how a RAIDZ1 system can end up with two drives resilvering tho....
Thanks,
David.
SweetAndLow
Sweet'NASty
It's still going because only some of the data can't be rebuilt. Any data that was on those 2 drivers is lost but data on other drivers is still there so zfs can return it to the user.
David Buchanan
So, 3 days later the re-silver completed. I've begun the replacement of ada0.
[root@nas1] ~# zpool status -v
pool: ZFS1
state: ONLINE
scan: resilver in progress since Sun Aug 21 21:07:20 2016
6.45M scanned out of 6.76T at 31.1K/s, (scan is slow, no estimated time)
1.22M resilvered, 0.00% done
ZFS1 ONLINE 0 0 0
replacing-0 ONLINE 0 0 0
gptid/bdc576aa-678e-11e6-bf2a-001f29554225 ONLINE 0 0 0 (resilvering)
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h11m with 0 errors on Thu Aug 18 03:56:21 2016
da0p2 ONLINE 0 0 0
The re-silver to replace ada0 is again slow. But my assumption here is that because ada0 is in such bad shape it's causing the slow re-silver speed.
Am I correct in my thinking?
Would I be better off shutting down the NAS even tho it's re-silvering at the moment and removing ada0 altogether and then letting it re-silver without ada0 being online?
Thanks,
David.
SweetAndLow
Sweet'NASty
You can let the resilver try to finish but you do realize your pool is trashed and you will have to rebuild.
joeschmuck
Old Man
Just out of curiosity, why did you ignore the drive failures back when it reported then at 25343 hours and now its 39977 hours? Also you don't appear to do any SMART testing. Look at that value for ID 197, holy cow! This whole problem could have been avoided.
I also think your data is corrupt and you would be better off just destroying your pool if you have a backup of your data and then restoring it.
Stux
Same here, hence the concern about possible pool corruption.
Data is written in blocks across all disks. Say 5 disks. You need to be able to read 4 of those blocks to reconstruct the whole block of data.
Since the drives aren't totally dead, as long as each unreadable data block is readable on the other drive... You should be fine, assuming the resilver finishes.
Let it run. Which ever drive finishes first, replace the other.
While you're waiting, burn in the replacement drive, and refresh your backup.
If you were using raidz2 you'd be fine.
The big problem with raidz1 is if you have a disk failure you have 100% loss of the blocks on that disk, if you then lose any other single block on any other disk, you get data loss.
Luckily you didn't have a total loss. Yet.
David Buchanan
Which directions for drive replacement are you following?
I'm following Section 8.1.10 of the Freenas guide: https://doc.freenas.org/9.3/freenas_storage.html
I don't have much of an answer. I do have a SMART test scheduled but I suspect I've configured something wrong. I assume those hours are coming out of the drive SMART info? As the NAS is no where near that old, but the drives where used in a previous system.
While I freely admit I'm no FreeNAS expert, I sure as hell would never have my data in just one place. As mentioned in the first post this is more about the learning experience and also seeing how FreeNAS handles situations like this. My data is safe, I'm not concerned at all. I'll be rebuilding the NAS in Z2 once I've had my fill of this.
Thanks for the input so far everyone! :)
Thanks,
David.
rs225
Since you aren't worried about the data in the pool, I would try running iostat -t da -x 1 on the command line, and see if two drives are actually writing. If only one is, I would attempt the swap of the failing/stalling drive. The other 'resilver' may just be some kind of glitch caused by timeouts of the first drive, but without any problem with the data.
